Old 11-11-2010, 05:01 AM   #1
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Cool deck height:
I'm putting together a sbc stocker motor for my Nova (71 350/270) . When I put the crank and one rod and piston together in the block, I had a positive deck height. Piston is out about .008. Can I put a thicker head gasket to make up the difference or do the tech people frown on this. Ihad this same thing happen about 20 years ago, got tore down at a race and it passed. I don't know now if the tech people are as benevolent as they were then
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 11-11-2010, 05:46 AM   #2
M&M Motorsports
Default Re: deck height:
Yes, it's covered in the rule book. Good Luck!
M&M Motorsports is offline   Reply With Quote
Old 11-11-2010, 10:40 AM   #3
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 306 Times in 103 Posts
Yes. they total gasket,deck clearance as long as you stay more than that
Mike Taylor 3601
Old 11-11-2010, 12:02 PM   #4
Jeff Lee
Jeff Lee's Avatar
My impression is that if the specs call for a negative deck, then the piston had better be below the deck of the block. At this point the gasket is not part of the equation.
The opposite is true if the specs call for a positive deck; the piston had better be above the deck of the block.
How much above or below the deck is not the issue as long as the blueprinted engine meets or exceeds the specs; more clearance is allowed, not less clearance.
Since your spec is .002" (below deck) then you'll have to machine the big end of the rods to pull the piston down to where it needs to be.
Note: this is the same issue as the rocker ratio rule. The end result is not the answer, getting there using the specs provided by NHRA is the requirement.
Jeff Lee 7494 D/S '70 AMX
Old 11-11-2010, 01:07 PM   #5
art leong
Jeff they used to go by that rule but have since changed it.
What would you say to someone that had a zero deck?
Some of the new rods (cracked caps) cannot be resized.
I got tossed once because I had a minus .020 deck and the specs called for a plus .004.
After that they changed the rule.
Art Leong 2095 SS
Old 11-11-2010, 02:39 PM   #6
Jeff Lee
Jeff Lee's Avatar
Then I would definitely get confirmation on it.
The "old way" meant if the specs were zero deck then it was zero deck. But as you say, that may not matter. But make sure you have the right rocker ratio when obtaining the spec'ed cam lift measured at the valve!
Old 11-12-2010, 06:52 PM   #7
Jeff Lee
Jeff Lee's Avatar
Geez...guess that puts me in old timer category! About when did this change?
When compared to the valve lift / rocker ratio issue, it makes no sense at all.
Old 11-12-2010, 07:10 PM   #8
art leong
I believe it was changed in 98 or 99.
I'm not sure but didn't the questionable rockers have the ratio stamped into them?
Art Leong 2095 SS
Old 11-12-2010, 08:22 PM   #9
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Cool Re: deck height:
I believe the ones that were caught earlier this year were stamped but NHRA was aware of this trick for years when one of Warrens 350 Camaros was found to have Crane 1.6 rockers on it and using an undercut cam to make the lift check right. It changed the opening speed of the valves more than anything.
Old 11-12-2010, 08:41 PM   #10
art leong
On the old Challenger we would shim the rocker stands to get the cam to check. It would change the geometry. I would think there are to many variables. If they check the lift at the cam there is no push rod flex ETC. And that can make a diffence especially with todays valve springs.
Art Leong 2095 SS
