What is a reasonable amount of converter slippage for a 2100 lb SG car running 1/4 mile?
Mine is 2400 lbs, runs 9.90 @ 152, have two convertors, a Greg Slack unit and also a spragless, slip is between 6 and 7%...
Dave Steltz 135G SG/SP/SST BIAECH Racing Team |
Liked 642 Times in 192 Posts
The converter manufacturer can build in any amount of slippage that you would want. For instance Hughes will take all you information they will custom build (Greg Slack will too) a converter to your setup. Hughes will give you one free tweak in the converter once you have run it to get it closer to your liking. 4 - 8% slippage is the general. Hope this helps.
so if you're running, 152 mph with 6-7% slip, you have to be set up for a theoretical mph of 163 mph?
Not sure what you mean by that....I measure convertor slip with my data recorder....Engine RPM at the stripe vs driveshaft speed, divide the two and there ya go...
I guess I may have more mph if it slipped less, or the engine might not have enough hp to pull more....
OK, so for example 7200 RPM, 4.30 gear, 32" tire theoretically is 160 - 163 mph so 7% slippage would give you about 152 mph @ 7200 RPM.
My converter is slipping a little too much but my mph is way down from where it should be based on hp/weight. My combination is 2140 lb roadster / 680hp / 4.56 gear / 32" tire and I'm barely running 139 mph at the stripe @ 7100 RPM. Too low a gear maybe? Thanks for the input. |
