Old 09-27-2010, 09:15 PM   #1
pro318
Unhappy need help with 60' times
i'm in need of some help with getting my car to 60 foot constantly on the stop. right now i leave at wide open throttle 6000 rpm(play back after every pass and it's at 6000) 6.5 psi in rear on hoosier. tires have about 30 passes use to run goodyears at the same. one pass it'll go 1.51 then the next run it'll go 1.60, then go 1.55. i've checked for coil bind, sticky calipers, line lock is releasing.
pro318 is offline   Reply With Quote
Old 09-27-2010, 09:19 PM   #2
Dave Steltz
Dave Steltz's Avatar
Default Re: need help with 60' times
Can you give us a little more info...
Whats your first number at
Whats your RPM on the stop
Whats your time on the stop
Approx Hp, and whats it run wide open
All could be helpfull in making a guess...plus do you have a data recorder or a playback tach ?
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 09-27-2010, 09:26 PM   #3
pro318
first number is .200. second number is around 2.00 dependes on the weather. makes 650 hp at 6700 shift on rpm at 7000. weighes 2400 with me. goes 9o's at 1.26 in 60.
Old 09-27-2010, 09:30 PM   #4
pro318
forgot 4300 on the stop and have a playback tach
Old 09-28-2010, 07:12 AM   #5
Lou SG2340
Are 60' times constant with the stop off? If yes, then you need to see if it is maintaing a constant RPM while on the stop.
Since you are shifting on RPM it will increase RPM while on the Stop. It needs to increase the same amount all the time.
Shifting by time might solve the problem.
Lou SG2340 is offline   Reply With Quote
Old 09-28-2010, 10:31 AM   #6
Dave Steltz
I would look at two things..
First I'm assuming that you are running 10.90 (with 2 secs in the stop)..
I would try shifting on time, like at .3, and see if that makes it any better...if you play back the tach, are you gaining alot of RPM before the stop comes off ? If so this could make you're 60's inconsistant...if you cant shift on time try lowering your stop RPM to 3900-4000, this can help with the RPM gain...
Secondly, you may be spinnning at the hit, are your reaction times varying with the 60 ? If you are spinning lowering your starting line RPM , along with changing your first number to .05 can help....
BIAECH Racing Team
