OK, after one weekend of climbing in and out of my car, some changes need to be made... The guy that welded the cage in (me) really should have dropped the door bars down a little lower!
I want to put in a legal swing out door bar kit. Looked at several, and ART or Alston's look nice. I have 1 3/4" x .134" tubes. The Comp. Eng. kit that Jegs and Summit just dosent look as good??? Your thoughts? Who is using what? thanks, Ken |
I used the Comp Eng. kit. Got it thru Jegs
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
Liked 99 Times in 60 Posts
consider this option; check with Alston Race Cars. They build a spring loaded latch that works great.
https://www.secureway1.com/alston/in...picture_id=133 |
Liked 43 Times in 29 Posts
S&W, it fits likw a glove
Mark Ruset 2048 STK |
Liked 886 Times in 238 Posts
I've used all of the above and they are ok, but the best kit I've found is the clevis type offered by Applied Racing Technology in Fla. ......Much stronger than anything I've used before............check it out https://www.appliedracing.net/ .......Tom
Liked 55 Times in 28 Posts
I'm using the CE but would recommend it only with reservations. The main issue is the angle it can pivot. you just can't get a lot of "opening" with it. I put the stub on the floor so it went outwards a little at the top. That helped the bar go onto the GM A body frame and still clear the seat. It also gave me more opening angle as about half is going one way from straight, and the other half is going past straight the other way. I carefully contoured the ends to get the most angle I could. Of course, the top clamshell is no problem; all it has to do it go over the stub tube welded to the hoop. I have both clam shells on the removable bar, with Moroso quick release pins.
Some of the kits seem beefy (=heavy?) while the CE is at least doesn't weigh much. Some exotic ones have spring loaded catches, etc. |
