Old 09-19-2010, 09:14 AM   #1
Dean3870
Default question for buick boys!
Well im starting on my 455 buick motor! I have been doing some research on line, and get some different stories! I have seen where you dont want to run more that 32, 34 deg. of timming, also, i now a stock buick motor dosent like any more than 5000 rpms, Is a stud gurdal legal in stock, and with it, and good bottom end what kinda RPMs do people recamend?
Thank you, and have a great day
Mike Dean
G/SA 3870
Dean3870 is offline   Reply With Quote
Old 09-19-2010, 09:19 AM   #2
MYRONARL1119
Default Re: question for buick boys!
Mike, Have you or your dad ask Billy Baker? I am ssure that he can answer your timing question. Don't think that the rule concerning valve train ssupport has been relaxed however. I am sure that Billy can tell you about your other stuff as I know that Dick worked with that combo in stock and super stock. Myron Stutes Columbus (X 3195 stock Nhra-now stock racer in remission)
MYRONARL1119 is offline   Reply With Quote
Old 09-19-2010, 09:33 AM   #3
Dean3870
Thanks Myron. i will have to look him up! the stud gurdal i was refering to was on the main caps, and far as the webbing in the block being to weak! but thanks for the help, i need all i can get lol
Mike Dean
G/SA3870
Old 09-20-2010, 06:53 PM   #4
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
I just sold ours, no girdle nothing special speed pro motor, it liked 32-34. It did not like a square lobe cam!!!!! Get a easy smoooooooth ramp. 6500 max rpm
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 09-20-2010, 09:19 PM   #5
SSGN
SSGN's Avatar
Liked 203 Times in 52 Posts
Cool Re: question for buick boys!
Send a PM to Tom Rix he is always more than willing to help Buick guys out.He ran a Buick in Top Stock and it was very competitive in the first season.Good luck and welcome to the dark side LOL
Kevin
Old 09-21-2010, 03:27 AM   #6
rowdyboys31
Mike I have raced 455 for a few years(lol) and have run the 350 the last year and half because the 350 make's alittle more hp per cubic in. I just got a new cam for the 455 and should have the 455 back in car soon. Ok back to your question, I run 38 or 39 degrees of timing. I use the MSD Dist. with all timing in at 3000 rpm in both motor combo's. The reason your stock 455 motor has a 5000rpm range is valve float from lifter preload (AKA) pushrods down in the lifter . I do not run any studs or girdle's for crank or valvetrain, RPM wise I spin my motor's in 5800 to 6400 rpm with 4.10 or 4.30 ring& pinion. Hope this help's you out, If I can help in any other problems e-mail me your questions at rowdyboys@comcast.net JOHN KEIHN 3954 G/sa-K/sa
rowdyboys31 is offline   Reply With Quote
