09-19-2010, 01:14 AM | #1 |
2008---262"Comp Elim/Top Dragster
2008 262" dragster complete or rolling.....6.00 certified chassis. comp eliminator,top dragster,Q16. double slip joint w/bolt thru adjusters. staggered front spindles. carbon dash,carbon drivers compartment,kevlar seat,carbon mono strut wing. titanium wheelie bar,titanium nuts and bolts. goodyear tires,american racing trac star wheels w/chrome black finish. stroud chute,(new) magna fuel pump w/filter. MSD digital 7530t,HVCII coil,new battery,11,000 rpm tach with matching gauges. A1 2 speed powerglide with dedenbear case....1.80straight cut low gear. aluminum center section,moser 40 spline axles........Coan 8" 8200 stall convertor.top fuel style body and windshield. car has complete vinyl wrapping with EZ removable. ENGINE=433 cubic inch BBC,manley titanium valves,16 degree olds big chief heads by CFE. JE pistons,MGP rods,bryant crank,LSM cam,JESEL keyed lifters,dual 1300 CFM carbs (braswell) custom sheet metal intake by CFE,dry sump,vacuum pump,davis step headers w/EGT's. 4-7 odd firing order,front drive distributor,belt drive,reactor flywheel,engine makes 1,075hp.........@1732lbs went 7.05@188...995 60ft. car gets light as 1555lbs with 185lb driver race ready.........complete race ready 38,500..................complete roller with tranny 27,500..........................roller minus tranny 26,000....................................delivery is possible on eastcoast with fuel payment... 504-269-7073.....434smallblock@cox.net
