Do you have to run a factory dizzy or can you convert to a crank trigger set-up in stock with a carburetor car ?
Jason Goldsack - 1997 Track Champion - St. Thomas Dragway 1997 Race of Champions Winner - Indianapolis, IN Div. 3 finals |
Only if the engine came with a crank trigger
Jeff Lee 7494 D/S '70 AMX |
OK...that makes sense..
I was just curious.. I guess that also gives the EFI a bit of an advantage.. Anyone modify a dizzy for a hall effect pick-up?.
Liked 31 Times in 7 Posts
I have run the Mallory Unilite for YEARS.... and no problems, knock on wood. The Mallory unilite is the "hall effect" design. The biggest problem with them is the ground. DO NOT ground them to an aluminum intake or anything aluminum. The block and or the frame is the best ground possible. They are easy to lock out if that is your thing too.
Rick |
