Im replumbing my car after 15 years or so because i took one of my lines apart and the fittings were rotted inside from the methanol!! I run a rear mounted fuel cell in a door car with a 4150 carb.right now my lines are 1/2" aluminum and -8 for the feed and return...im changing to all braided hose to get away from as much bare alum as possible..my question is do you run -8hose or -10 hose or -10 for feed/-8 return thanks
scott fifield |
# 10 stuff for all
jj h/r 1399 s/r 1399 ![]() |
#3 | |
You might want to consider a smaller front mounted fuel cell as then the g-forces work with you not against you and the lines are shorter.
Bill Baer 3391 SC, 339B SC, QR Last edited by Bill Baer; 08-18-2010 at 04:59 PM. |
I just redid mine with a similar combo. I had 1/2 inch aluminum. Which was fine. I replaced it with #10
