Old 07-24-2010, 09:20 AM   #1
FINESPLINE
FINESPLINE's Avatar
Default Stocker camshafts
In the past year I have finished the body and chassis on my 1970 Nova with the intention of making it a legal NHRA stocker. I joined this site to get an idea of what goes on in the class and I have to say that it truly is a wealth of knowledge. I am at the point of decision about the powerplant and the class options it offers. Could anybody offer any insight into camshafts as they seem to be the unknown factor. I have never heard anybody talk specs since the only real spec is the lift limit as per the factory cam. One more thing, the car will definitely be a stick. Anything that you would have to offer would be appreciated. Thanks, John
FINESPLINE is offline   Reply With Quote
Old 07-24-2010, 10:42 AM   #2
larrylomascolo
Liked 77 Times in 31 Posts
Default Re: Stocker camshafts
Let the guys know what combo you are going to use,car falls into a few,and you will get a wealth of knowledge on this site.
Old 07-24-2010, 11:05 AM   #3
Liked 1,924 Times in 432 Posts
John,
Your car can fit into several classes, with several engines and 3-4 years (69,70,71,72, and 68 if no one looks too close ). From a 6 cylinder, to a 2 barrel 307 V8, to an aluminum head 396/375. You really need to pick an engine, transmission, and year for your combination, then pick a guy to either build the engine, or at least supply you with parts and technical assistance, as well as machine work. I could tell you about cams, or send you to the guy who does mine, but if that isn't what the guy you pick to do your work does, it won't help you much.
There are some combinations that you can go with that will be pretty quick, for example a 69/70 350/300 stick, or 69 396/375 iron head stick. There are some quick 69 350/255 automatic cars, and that makes a good stick car as well. The 70 402/375 stick isn't bad, either. It depends a lot on how fast you want to go, and how much you have to spend.
Old 07-24-2010, 12:35 PM   #4
ron mattson
Liked 69 Times in 32 Posts
If you plan on running a small block combo i have tried them all and tried over 15 sticks in all different combo's and can get you going in the right direction. p.m. me and let me know what you plan on running and ill give you my .02
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 07-24-2010, 02:05 PM   #5
350 /250/230 2bbl, M/Stock @3390 lbs.
70 is better than a 69 with a 2bbl. You'll have to dig a little to find out why...
Old 07-24-2010, 04:13 PM   #6
Adger Smith
Liked 880 Times in 311 Posts
Mark,
Why didn't you just tell him it would have about 10 cc more POP?
Or say it would run better in bad air?
Adger Smith (Former SS)
