Old 07-21-2010, 12:12 AM   #1
Janne
Janne's Avatar
Default tires
need some input about tiers 30-9.0-15 for 4-speed chevy BB stocker(B/S)
I run now Toyo.(the toyo works good)
which is best for that car I like to test some differents manufacturs
Janne
Janne is offline   Reply With Quote
Old 07-21-2010, 12:58 AM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: tiers
I have also run the Toyo's but the standard for 4-speeds are 29.5x9S M/T's.
You can PM me if you like.
Jeff Lee 7494 D/S '70 AMX
Old 07-21-2010, 07:52 AM   #3
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
Default Re: tires
Will radials work on a stick car?
Larry Curtis is offline   Reply With Quote
Old 07-21-2010, 08:47 AM   #4
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Question Re: tires
I know the traditional answer is no, but I too wonder as a dragpak has a very different suspension system than traditional stockers.
Anyone?
Eric Merryfield 1883 STK
Old 07-21-2010, 03:09 PM   #5
Jeff Lee
Jeff Lee's Avatar
Default Re: tires
For Larry, the answere is no...but that doesn't mean that somebody could tackle it and be the one who figures it out. But for a new stick racer and combo, sort it out thoroughly with bias slicks and have a complete understanding of how the parts interact before attempting a radial transformation.
And it's not like any DP Challenger needs an extra tenth or so anyways...right
Old 07-21-2010, 03:45 PM   #6
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default Re: tires
Local bracket guy asked me about the radials because he had the MT Bias. I told him they are usually good for .06-.08. He said that was exactly what he picked up using tubes.
Things that make you go Hmmmmm.......
Daran Summerton is offline   Reply With Quote
Old 07-21-2010, 06:12 PM   #7
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default Re: tires
Anyone?
Eric, can I ask what front susp you are running ? Strange Here.....thinking of making a change.
Cheers
Chris
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
Old 07-22-2010, 11:08 PM   #8
JRyan
Liked 112 Times in 31 Posts
Default Re: tires
Larry, there are many higher-classed Stockers working well with a Stick & Radials right now. A couple of them are right there in Minnesota.
Jerry
