Old 03-21-2010, 11:44 PM   #1
Rory McNeil
Default 1964 Comet headers
A buddy of mine has a 64 Comet Caliante bracket car with SB Ford, 4 speed, and his old custom made headers are falling apart. Are any "off the shelf" headers available with 1 5/8" tubes, that work with the factory clutch linkage, and clear a scatershield? Supposedly early Mustang`s have a different firewall, and the headers are not interchangable. Thanks.
NHRA 6390 STK
M/S 85 Mustang
Old 03-22-2010, 11:10 AM   #2
Jim Caughlin
Liked 808 Times in 247 Posts
Default Re: 1964 Comet headers
I used to run the standard Hooker 1 5/8 on my Comet years ago and they fit reasonably well with the clutch linkage. As I recall, I had to do the typical 'illegal' trimming of the scattershield flange to make them clear. If you get desperate and want to bring the car down to my shop, I can build a nicer and more equal length set and/or maybe repair the existing pieces.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 03-22-2010, 08:56 PM   #3
Mile High
When I went to a 351W stroker in my Falcon I used headers from a company called Tubular Automotive in Mass. 1 5/8" tubes and 3" collector. Now using headers from Crites Performance 1 3/4" tubes and 3 1/2" collector. I did some cutting on the shock towers for extra clearance too.
Mile High is offline   Reply With Quote
Old 03-23-2010, 09:08 PM   #4
69Cobra
Liked 2 Times in 2 Posts
We also have a set of Crites but have not put them on yet. I've seen them on other 64 comets and all looks well.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 03-24-2010, 12:43 AM   #5
Rory McNeil
We have only seen photo`s of the Crites headers. The front tubes look much, much longer than the rears, and my buddy doesn`t care for the way the front 2 tubes on each side are routed under the lower control arms, ground clearance wise. He plans to patch the cracked tube(s) for this season, but is hoping to find something good for next year, without breaking the bank.
NHRA 6390 STK
M/S 85 Mustang
Old 03-24-2010, 09:28 AM   #6
Mile High
I also cut off the sway bar mount brackets and you need to reposition the oil filter too. They do hang real low.
