Old 03-12-2010, 10:09 PM   #1
Joe Toller
Liked 9 Times in 9 Posts
Default Big silly rookie question
I think I'll have my 87 Lancer turbo ready to go Stock racing, and it looks like I'll have to head to a Divisional in ID or BC to run. My big silly question is, how does the whole teching, registering and classifying the car for Stock go? All I've ever done is run sportsman brackets at home. Just wondering what I need to do ahead of time, and what to prepare for at the event. Thanks in advance!
Old 03-12-2010, 10:23 PM   #2
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Default Re: Big silly rookie question
What combination do you run? Most cars are eligible to run three different classes (it's natural class, up one, and down one). Once you tech in in a particular class, you can not change it. Might want to head to the scales before teching, to see what the car weight is (with driver), to see what adjusments might be needed. Some cars will do "better" in a different class, based on weight and Index.
Old 03-12-2010, 10:33 PM   #3
Mike Carr
Mike Carr's Avatar
As far as what you'll need when you go through tech and registration:
-Your NHRA Stock Competition license and NHRA membership
-Tech card filled out accurately and completely
They will check your helmet, that it meets specs, and for a seatbelt. They may ask to have you open your hood and trunk to look at things (make sure battery is secure, overflow tank of sufficient capacity, etc). Once they OK and pass you, you're done until the first time trial. Like I said earlier, you might want to check the weight at the scales before teching, in case the car is heavier/lighter than you may have thought (all scales can read different). If you can not add/take out enough weight to make that class, you may have the option of moving up or down a class, as long as you can meet the minimum weight with driver.
Old 03-13-2010, 11:38 PM   #4
Joe Toller
Yes, 135 cid turbo
Old 03-15-2010, 10:35 PM   #5
Mike Carr
Mike Carr's Avatar
The Sedan 4 door breaks at 16.50, making it a natural BF/S, meaning it can also run A and C, with weight adjustments. The Sedan 4 door SE, breaks at 16.86, and will fit the same three classes. It's factory rating is 146, with an NHRA rating is 160. So you will multiply 160 x the class weight break, add 170, and will give you the minimum weight for each class, as follows.
AF/S 13 x 160 + 170 = 2,250 pounds minimum weight (seems highly unlikely that your car could get to the class' minimum weight. Class Index is 13.85 seconds.
BF/S 16 x 160 + 170 = 2,730 min wt. Class Index is 14.65 sec. This is the closest weight to the cars natural factory shipping weight.
CF/S 17.5 x 160 + 170 = 2,970 min wt. Class Index is 15.15 sec.
Hope this helps.
Old 03-16-2010, 07:05 PM   #6
Joe Toller
Thank you very much for that info. I was wondering what class I'd be in. Think I need to see what it'll do, and I'm betting I'm closer to CF weight because this thing is loaded to the nines. I'll go get it on a scale this weekend and go from there. Thanks!
I also have an 86 Lebaron GTS, and it's manual windows, non-tilt etc, probably would be a great car too, and lighter, and I could always swap stuff over since the mechanicals are the exact same. Guess I'd better get to work!
Thanks again!
Old 03-12-2010, 11:01 PM   #7
Steve Williams
Excellent advice!
Steve Williams is offline   Reply With Quote
Old 03-13-2010, 01:24 AM   #8
Dion Hildebrandt
Dion Hildebrandt's Avatar
[ Once you tech in in a particular class, you can not change it. Might want to head to the scales before teching, to see what the car weight is (with driver), to see what adjusments might be needed.
Good advice, the first time I teched my chevelle as a stocker, I had issues with weight and went up to the tower to change designations twice. All this effort earned me was a visit from the head tech inspector for verification that me 'velle fit into the claimed class.Double check and recheck your safety equipment as the div 6 guys pay particular attention to those items ,other than that be ready for some schooling! Oh try and get the guy that is smiling he is more likely to have a sense of humor and less likely to take his foul mood out on you!
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 03-13-2010, 08:07 AM   #9
Jim Cassels
All good advice, don,t forget your fuel check valve.
Jim
Jim Cassels is offline   Reply With Quote
Old 03-13-2010, 08:51 AM   #10
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Jim
thats a biggie right there,,with your fuel injected car you can put a shut off valve in place of the schrader valve off the fuel rail gmonde
