Old 02-28-2010, 06:54 PM   #1
Cosmikdebris
Default Dragster
Hi all
I'm new to this board, and have few questions.
I want to run a entry level RED, the car has a cert. to 7.50 and a sbc
with PG and no electronics. I want to start out at 10.00 sec. and slower. What are my choices?
Thanks
Cosmikdebris is offline   Reply With Quote
Old 02-28-2010, 07:53 PM   #2
sg1586
Default Re: Dragster
You can put a "down the road" 5.7 in and go 10s...A mild
SB will put it in the 8s......
sg1586 is offline   Reply With Quote
Old 03-01-2010, 11:59 AM   #3
Bill Baer
Mike
You could put a 283 in it and it will still probably run in the nines I would suggest that you bite the bullet put a decent 350 in it and it should run high 8's or low nines get your self a physical, make your license passes send the nice lady in Glendora your paper work and $100 an get yourself a shiny new NHRA license.
The local dragstrip is probably going to make you buy all the up to date safety stuff (SFI Helmet, SFI /5 fireSuit/gloves /SFI belts, Balancer, flexplate, flexplate shield, transmission shield and chassis certification)anyway, so you might as well go faster.There are some advantages in doing so (i.e. if they leave first they can also redlight first, you will usually have you opponet in front of you ect.)
You may find a dragster a little intimidating for the first few passes but they almost always go strait and are actually easy to drive.
