Old 01-17-2010, 10:19 PM   #1
Kegracing
Default what size front tires on 67 Firebird?
How big of a front tire can I run on my 67 Firebird? Have all "stock" suspension on it. Nothing moved or enhanced... Want the biggest I can get without rubbing.
Thanks in advance!
Ken
Kegracing is offline   Reply With Quote
Old 01-17-2010, 10:27 PM   #2
Default Re: what size front tires on 67 Firebird?
Ken ,That would depend on the offset of the rim.
Old 01-17-2010, 10:49 PM   #3
Kegracing
Good point, thanks Mark.
They are 15x4 draglites, but I will have to measure tomorrow. Not sure if there is more than one offset on that size or not.
Old 01-18-2010, 08:09 PM   #4
Kegracing
3.5 draglites with 1.75 back space
what fits?
thanks
Ken
Old 01-19-2010, 02:01 AM   #5
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
27.5x15 will work just fine
Old 01-20-2010, 01:09 PM   #6
mannymen
Liked 13 Times in 7 Posts
Running the Hoosier 18107's with no problems.
# Tire Size: 28/4.5-15
# Tread Width: 4.5"
# Approximate Diameter: 27.7"
# Circle: 87"
# Recommended Rim: 3.5 to 4"
# Measured Rim: 4"
# Section Width: 7.6"
# Tire Weight: 12 lbs
N/A
mannymen is offline   Reply With Quote
Old 01-25-2010, 12:47 PM   #7
LittleBubba
i dont know if your trying to obtain more rollout for r/t, taller ride height, or just the look of having a filled-out fenderwell but i dont believe they make anything bigger than a 29" in which case theres not going to be much difference from the 28" that you have now. if anything, borrow a set of 29's if you can just to stick on and see how much room you have
LittleBubba is offline   Reply With Quote
