Liked 17 Times in 9 Posts
I'm looking for any help or suggestions on some rear slicks....I run a S/ST Camaro with a 15x15 wheel and currently running a 33x15 Hoosier. I've always run right around 8psi.
My problem is I seem to kill the side walls in only about 60 passes. I have roughly 300 lbs of ballast in the trunk to make s/st weight. Is this why I kill the sidewalls so fast? I've never run any tire other than Hoosiers, but I'm open to any other out there if I can get more life out of them without sacrificing 60' times and performance. Any input is GREATLY appreciated! Thanks for your help in advance! Mike Boehner S/ST 5167 |
Liked 3 Times in 2 Posts
I run a 90 Mustang right at 2850# on 28x10.5's and can get between 100 - 150 runs out of a set of tires, and run between 7.5/8.5# air in them depending on the track...
May want to try a stiff sidewall tire if you can find them in your size... Also, 300# of ballast??? not all bolt in I hope...
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
Thanks for your help and input. I figured a stiffer sidewall would help, but I don't have the time or money to test a bunch of tires. Was hoping for a few suggestions of things you guys have tried and learned. Thanks again!
I would put a set of stiff sidewalls on it. I switched to stiff sidewalls on my 10.90 car, 68 Camaro that weighted about 3100. Made the car more consistant, quicker reacting, and went from 100 passes to 200 passes out of a set of the Goodyears. I kept the 14.5 x 32 stiffs on it the last couple of years I had it.
You might be able to run a little more air pressure also... on new tires I would try 10 psi and see what you get. Good luck. Ken |
Ken,
Thanks a bunch for your input. To be honest with you I was leaning toward trying out some good years, unless I got some feed back that suggested another direction. Do you have any idea what compound? Thanks again! |
Liked 229 Times in 99 Posts
If you aren't running tubes you might want to consider them. They helped my reaction time.
Floyd Staggs 787 SST |
Liked 21 Times in 6 Posts
Call Larry Hodge Tires and Wheels he can help you out great prices also he is a sportsman racer 217-433-3060
