Liked 18 Times in 7 Posts
I have a new B&M shifter installed in my car,,,
If I hook the cable up to the trans it works really hard? If I take it off the trans it works fine, Anyone got any Idea's what to look for? Thanks, Ken |
Liked 203 Times in 52 Posts
Check cable for a rough feeling when disconnected.Very slight,poss causes would be cable pinched or kinked at the factory or shipping.Some oem cbls would do this when I worked at a dealership.Hope this helps.
Kevin |
If your trans shifts ok by hand, I would guess the cable is in a bind (not enough of an easy bend) That's my .02
Liked 56 Times in 27 Posts
Ken,
Try what Bob said to do.... Make sure the tranny arm shifts easy by hand...If thats OK, check for a kink in the cable.. Try taking it off trans again and adjusting it in each gear to see if that helps ? Make sure you only remove at the eye-let , so the cable is still in the bent position... I think you may find it's in the tranny arm ? Good Luck & Merry Xmas....
Dave Ribeiro 1033 STK |
the cable is in a bind... been there done that
