Do you stick shift guys use a RPM pick up in the bell for clutch RPM? Is there room in a stock depth bell? I am leaning toward a Quick Time bell.
Liked 333 Times in 180 Posts
under the front bearing retainer that way you have 2 channels ---one for engine rpm and one for trans rpm---comp387
My question is, can that apparatus be squeezed into a stock depth bell housing? - Goog
What a clique! Thanks for all your help. I will not post here again. It's obviously too much trouble for you guys to post a simple "yes" or a "no", so I give up. I am very confident that one of you experienced, intelligent gentlemen know the answer to my question, but you all read my post and move on. I have been lurking here for a while and learned a lot. I've seen some silly questions get a ton of responses. But If a stranger asks, the plug gets pulled. That's fine with me, I'm out. There's obviously not room for one more member in this clique! But,now that I know the deal here, I don't want admittance. - Tom
Goog yes, nice tantrum.
Look, "Goog" Not a lot of people run the sensor up there, but it is a better deal if you do. I would think it would fit, most drill into the bearing retainer and input then it would fit. Depending upon the trans and data collection device you have, you might be able to buy it. Most just go the easiest route and put the collar on the driveshaft and use rpm input from the ignition.
Suggestion: Why don't you start out by telling the general public on the forum (that you expect this response from) more about yourself and the car you are assembling. Maybe tell the experts why you are looking for an urgent response. Maybe offer an appreciated but hopeful deadline if it is needed. Some alternative contacts like e mail phone, etc. Remember, less than 10 percent of the racers in Stock and Superstock run a stick so your expectation (which apparently was F'in immediate) is probably not a reasonable one . I don't think it is fair to anyone to throw out such requests with no stated expectation and then go nuts on people when you don't get what you want. I saw your last post in May and it was the same whiny response from you when you said you were buying an auto trans. I have no expectations with regard to a response, but if you do read this and you are building a SSDM with a stick I think that is a cool deal. I sure don't know it all, but I have run Modified stick shift cars and do also run a stick shift stocker. I think stick guys generally help each other out, but we don't have time to lurk on the forum every day. I work 6 days a week this time of year and am trying to fit in some time for the race car with what is left. I am leaving to go do this today, so you can feel free to e mail me at jimschaechter@earthlink.net or if you need an immediate response, call me at 563-505-0293. If I can't answer your questions, I will refund your money! LOL.
James Schaechter 3163 STK |
