Old 11-17-2009, 07:00 PM   #1
EJB40
Default question on lauches
i hope this isnt a dumb question but can some please tell me how the stock elim guys get the wheels up in the air like they do i knoe you have to have good rear suspenion but what else thanks
EJB40 is offline   Reply With Quote
Old 11-17-2009, 07:19 PM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default Re: question on lauches
Lots of gear & lots of converter!!!
Old 11-17-2009, 07:29 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: question on lauches
.....and lots of carb tuning. Probably more important if you footbrake as opposed to using a 2-step.
Old 11-18-2009, 12:55 PM   #4
Jeff Lee
Jeff Lee's Avatar
lots of weight in the trunk. Some of the upper class cars have 300#'s or more in ballast!
I was helping a friend with his J/SA car this weekend. Finally has a convertor that is right for the car as he's gone from too loose, too tight to just right. So says Goldilocks..
Thanks for Yaccavone convertors in getting it right the first time (he didn't do the other two).
Now it's obvious to me the car still wasn't launching right. It basically just moves forward w/ no body movement. It did pull the tires about 4" off the ground but it was all pretty unspectacular looking. Best 60' was 1.63 with radials (this is in AZ). After discussing what his experience was when he softened the rear shocks up I determined the rear springs were probably shot. They are a multi-leaf w/ Cal-Tracks. So my suggestion was replace the springs with Calvert springs which should be about 40#'s lighter and more effective at the same time. Place the saved 40#'s in the trunk (he already has ballast in the trunk), He has a standard battery up front so I told him about a cheap battery that will save 15#'s up front and there's another 15#'s in the trunk. The Calvert front shocks are better on extension and have more travel and I know they work better than the QA's he has now. I'm betting there's .05 on 60' time with these simple and somewhat affordable improvements.
Jeff Lee 7494 D/S '70 AMX
Old 11-18-2009, 02:27 PM   #5
Rich Aceves
No one has mentioned that a little horsepower does'nt hurt!
Rich Aceves is offline   Reply With Quote
Old 11-18-2009, 07:56 PM   #6
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
X2
also the front end plays a big part in the "wheelie game" as well. Everything loose as passible without sacrificing safety. All my bolts are double nutted and the upper control arms are very loose. Everything has to move smooth. Stockers usually leave hard because they are close to 100% efficient meaning the car is way better than the engine. My car left ok but after 3 days on the scales moving weight around its perfect. Probably would go faster with a less violent wheelstand but its cool and on a "so so" dragstrip it will spin if it doesnt get up on the tire. Just my 2 cents...
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 11-18-2009, 10:18 PM   #7
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Wink Re: question on lauches
Originally Posted by CrateCamaro View Post
X2
...and that's 2 Canuck cents which will almost buy you an opinion on the open market these days!!
Hey TV, how was the breakfast?
Dave Turner
SS/GT #1153
Old 11-19-2009, 10:01 PM   #8
CrateCamaro
hahaha....breakfast was good as usual. I was hoping to see you there.
1700 IHRA H/CM
1701 NHRA SS/?A
Old 11-19-2009, 10:37 PM   #9
Dave Turner
First one I've missed since joining the series - our holidays started the day before.
BTW, you've done a great job with the "Bandito" web site!
Dave Turner
SS/GT #1153
