Old 11-13-2009, 12:01 PM   #1
68camaroSS
Default 2004 silverado instrument cluster guages
Thought I would post this to see if anyone had experienced this. I have a 2004 Chevy dually. At 82,200 miles, the speedo completely malfunctioned. I called GM and they said it will need a new instrument guage cluster, cost about $600 for the unit plus labor. There was special coverage (not a recall - a recall would be good indefiently) letter sent to owners from GM to cover this defect, within 7 years or 70,000 miles. GM Customer Service stated that because of a class action law suit, that coverage was extended from 70,000 to 80,000 miles. That still leaves me left out, being about 2,000 over the milage. They would not budge on helping me with the repair bill. The lady I talked to said the decision was final, and I could not appeal my case. The dealer says the same. Am I out of luck, or does anyone know anything else I can do, since this is a known manufacturer defect and an unsafe condition? thanks,
68camaroSS is offline   Reply With Quote
Old 11-13-2009, 12:18 PM   #2
Stick Racing
Default Re: 2004 silverado instrument cluster guages
Had same problem with 2002. Also friends 2004 GMC. I could never get it to malfunction for dealer. We both knew what problem was but they wouldn't fix it. After about five years, I went to the local GMC dealer to pay the $600. Couldn't take it anymore. (Not gonna patronize Chevy dealer I bought it from).Good friends with service manger so I had to pay 'co-pay' for $50.00. Haven't had a problem since. Also hve a 04 with 6.0 engine. Popped two heads off exhaust mainfolds with 36200miles- 200 miles over warrantry. Refused to fix it.There's a reason they are bankrupt.
Andy Stone
Stick Racing is offline   Reply With Quote
Old 11-13-2009, 01:25 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 2,013 Times in 604 Posts
My 2005 Silverado did the same thing. I just use the GPS now for speed. I know what the tach should read at certain speeds. I found a speedo repair place in Tampa Fl that reconditions them for a cheeper rate. Look for them on Google key in speedometer repair. As I remember they will ship anywhere.
Mike Pearson 2485 SS
Old 11-13-2009, 02:06 PM   #4
buzzinhalfdozen
Liked 11 Times in 8 Posts
There are several places that can repair your IPC much cheaper than replacing it.This was a known issue for quite some time all our customers that complained of it got a new IPC even if we couldn't duplicate it. Right now it's extremely difficult to get G.M. to "good will" anything for years it was basically covered if asked for, I think they've really tightened up to obviously save money. Joe
Joe Buchanan SS/BX 3117
Old 11-13-2009, 02:41 PM   #5
Lambertcars
Your Dealer that you talked to is overcharging you for the inst.cluster,I work at a Chevrolet Dealer in the Service Dept.and when a customer has a promblem with the spedo,tach or any gauges we connect the Tech 2 to the diag.plug and check the cluster gauges and it will tell what gauge are bad,then we get the part number of the cluster useing the Tech 2 and the Parts Dept will get a reman cluster overnight and replacment of the cluster and reprograming is about $375.00 for everything.also the years that we see the promblem is 2003-2005.Dont let the Dealer you are dealing with tell you that you have to have a new cluster,when they can get a reman.for your veh.
Lambertcars is offline   Reply With Quote
Old 11-13-2009, 03:50 PM   #6
buzzinhalfdozen
Last I heard was only remans. were available, not sure on the cost of one through our shop as it's all Warranty and don't see the prices on my R.O. I've never yet had to price on for CP so I'm sure you're correct on the price. Don't forget that these clusters have to be set up and programmed after installation, well most of them. We've had some sent that were already setup and programmed. Joe
Old 11-14-2009, 07:37 AM   #7
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
68camaroSS, send me a PM maybe I can assist you with GM.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 11-14-2009, 02:43 PM   #8
Detroit Bob
Liked 8 Times in 3 Posts
Try this guy, my son is ready to take his cluster out of a 04 Bonneville and will probably send it to him.
http://cgi.ebay.com/ebaymotors/2003-...Q5fAccessories
Bob Kowal STK 345
Detroit Bob is offline   Reply With Quote
Old 11-16-2009, 02:18 PM   #9
stocker4046
Look for another dealer. I have a 2005 and two different dealers, one in Baton Rouge, LA (chevy) and the other in Atlanta, GA (GMC), extended the replacement to 100,000 with me paying only $175.00 for labor at 90,000 miles. Only reason I replaced it was to get the truck inspected.
stocker4046 is offline   Reply With Quote
Old 11-16-2009, 02:45 PM   #10
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Thank you! My cluster has been fubar for awhile now. I'm going to try replacing the motors myself.
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
