Old 10-01-2009, 07:17 PM   #1
Hemiparts
Hemiparts's Avatar
Default Hood Question ????
I see pic of cars in SS running fiberglass hoods,but from my understanding of the rule book you have to use a "factory hood" Does this mean factory appering ( fiberglass that bolts to hinges ) ????? This is the last piece of the puzzle before we start testing for next year.
Hemiparts is offline   Reply With Quote
Old 10-01-2009, 08:21 PM   #2
treessavoy
Liked 4 Times in 4 Posts
Default Re: Hood Question ????
Good question.
There is a picture of a rambler M/SA with a 290ci engine at the Columbus race with a factory hood scoop that only came on the 390ci version.
If that's legal why can't I run a max wedge scoop from a '64 plymouth 383ci car? Or any '64 plymouth other than the Aluminum scoop cars?
JimR
Jim Rountree
Old 10-01-2009, 08:22 PM   #3
art leong
In the real SS/ classes factory hood means just about what it says. If a car came with a nhra accepted fiberglass hood you can run it (and there are some aftermaket hoods that get thru). But you can't replace a steel hood with a fiberglass one unless nhra accepts it. This pertains to the SS/ classes.
Art Leong 2095 SS
Old 10-01-2009, 08:54 PM   #4
Jeff Lee
Jeff Lee's Avatar
Regarding SS classes, if the car came with a steel hood, you must run a steel hood. You can only run a scoop if the car came with a scoop (or shaker, etc.) in the "traditional" Superstock classes). In the GT classes you can run a scoop.
If the car came with a fiberglass part and it is recognized by NHRA, you can keep it that way and it appears you can get away with a carbon-fiber replica. I would confirm with other racers in your class on that.
If your car came with an aluminum part or fiberglass part, you can run a heavier steel version. This is common with aluminum front end mopars for example as the parts are super-pricey and extremely difficult to find. The idea here is you can go heavier, not lighter.
A 290 Rambler in M/SA with a '69 Hurst SC/Rambler (390 4-speed only) would not be legal in NHRA Stock. Maybe it was a IHRA class? I'm not familiar with all of their Stock classes. There probably isn't a better hood scoop out there than that unique snorkel hood scoop. It probably captures as much air as necessary without the aerodynamic problems of something like a '68 Hemi A-body scoop. That's layman opinion not wind-tunnel opinion.
Jeff Lee 7494 D/S '70 AMX
Old 10-01-2009, 10:05 PM   #5
Jeff Lee
Jeff Lee's Avatar
I'm talking about traditional (not modified) SS classes with OEM scoops. If you have a '68 Hemi 'Cuda you get a scoop for SS/AH. If you want to take that same body with scoop and put a 383 in it and run it as a GT car you may. Does that answer your question?
Jeff
Old 10-02-2009, 06:20 AM   #6
Hemiparts
Hemiparts's Avatar
Where would you find this "list" of acceptted hoods. In my case I have a 71 Duster and I know some left the factory with a matte black fibergalss hood. If thats the case I'll just add hood hinges to my fiberglass hood and I'm ready to go.
Old 10-02-2009, 10:07 AM   #7
Jeff Lee
Jeff Lee's Avatar
'71 Dusters came with a steel hood. If you had a 340 Duster it had a pair of fiberglass scoops bolted to the steel hood.
The only post 1970 A-body with a light-weight package is the "Dart-Lite" & "Feather Dusters" as I recall in 1974 with aluminum hoods and other light-weight components. It was a fuel mileage package with slant 6's and overdrive aluminum case manuals trans.
Old 10-02-2009, 12:12 PM   #8
art leong
Hey Jeff. My hood scoop is not a hood scoop it's a front mounted parachute. Works similar to lifting at 1000 ft mark
LOL
Art Leong 2095 SS
Old 10-02-2009, 01:27 PM   #9
Sean Haning
Sean Haning's Avatar
Send a message via AIM to Sean Haning
LOL
Yeah if you took that off, Tim would be in trouble, lol.
Isn't there a "list" that for instance allows the Challenger T/A 6 pack hood to be used on non T/A cars? Or was that just one that slipped through the proberbial cracks?
Hired gun w/o gun.
Sean Haning is offline   Reply With Quote
Old 10-02-2009, 01:40 PM   #10
treessavoy
Sean,
The story from Mom Mopar was that they ran out of "shakers" on the assembly line and substituted the T/A hoods instead. Supposedly a letter was sent to the NHRA stating such. The funny part is that Plymouth didn't seem to run out of "shakers".
Tree
Jim Rountree
