Old 09-26-2009, 10:47 AM   #1
JMatt
JMatt's Avatar
Default SG Door car tire pressures
Just curious where people are finding their best tire pressures. I search, but most threads seem to come from dragsters running 5-6 pounds.
I'm in a 2600 pound door car. Currently 60' in 1.200 seconds. 1.80 glide, 4.30 rear end. 104" rollout rear tires (NOT stiff sidewall).
I run about 9.5 pounds hot. 8.5 cold. +/- based on weather.
Too high? Too low? Just right?
JMatt is offline   Reply With Quote
Old 09-26-2009, 03:06 PM   #2
JMatt
JMatt's Avatar
Default Re: SG Door car tire pressures
No Super Gas cars on this forum?
Old 09-26-2009, 04:58 PM   #3
GRIGGS
The more air pressure you can run the better. It will also help your rt. I run anywhere between 10 to 12 lbs. depending on track conditions, but I do run more than most. 3200 lb Chevy II. Hope this helps some.
GRIGGS is offline   Reply With Quote
Old 09-26-2009, 06:05 PM   #4
JMatt
JMatt's Avatar
Sure that helps. Thanks. Love to hear more people's examples too.
Old 09-27-2009, 05:30 AM   #5
Lou SG2340
7lbs on a 2250lb roadster with 33x16 Hoosiers. Same pressure hot or cold
Lou SG2340 is offline   Reply With Quote
Old 09-27-2009, 12:38 PM   #6
frank v
i run 8lbs in a 2550 door car hot or cold
s/g 1620
frank v is offline   Reply With Quote
Old 09-27-2009, 06:33 PM   #7
JMatt
JMatt's Avatar
Same pressure hot or cold? Don't your cold tires coming off the trailer heat up enough to add a pound from the first burnout?
I'm trying to get to about 9.5 pounds immediately after the burnout. That's why first pass I have set about a pound lower.
Am I doing it wrong?
