Liked 333 Times in 180 Posts
My grandson has a 66 GTO with the 389 engine AND HEADERS--- does any one know of a short or shorter than stock oil filter that will work so that we do not have to drop/remove the headers to change the oil filter every time ---thanx Comp 387
Dick,
Tell your grandson to put in a Chevrolet engine and that will cure the problem. Hope all is well. Steve |
Steve ---this car is too nice to do that ---but a good idea tho---been recuperating from prostrate surgery now, kinda screwed up my summer--- hos your dad doing??? say hi for me--thanx Dick
a caddy filter from a same year is shorther and same thead chuck
Chuck --thank you!!!
Liked 239 Times in 114 Posts
Pontiac also had a filter adapter that rotates the filter back at a 45 deg angle . Available from some of the Pontiac restoration sites. Used on Gen 1 Ram Air Firebirds, and 428 HO in 67-69 B-bodies. Then you can run a full size filter.
thnx to all that replied----- after digging thru thru the Napa parts bins we found that a 98-02 Camaro will do the job----again thanx to everybody---Comp 387
