Old 08-14-2009, 08:46 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default epoxy for use near gasoline
Gasoline proof epoxy
Racers,
What brand/type epoxy is suitable for use in the carburetor air horn and booster area? Specifically to form a radius near those areas. Not that the material will be submerged in gas, but some contact from gas will happen in that area.
Thanks
Larry Woodfin 471W
Old 08-14-2009, 11:32 AM   #2
Dragsinger
Default Re: epoxy for use near gasoline
Thanks for the private reply's, I have the needed info.
Larry Woodfin 471W
Old 08-15-2009, 08:57 AM   #3
njk53
JB Weld would be my choice. Look at their website they say their product is good for fuel cans and fuel tanks so I think it will be OK for your application. Once that stuff cures it is as hard as the sidewalk. It also can be drilled or machined. Drawback is it takes 24 hours to cure properly.
To be on the safe side, try a trial area on the materials you are going to epoxy to make sure it is compatable.
Nelson Kowal
Stock 345
Old 08-15-2009, 09:17 AM   #4
FED 387
Liked 330 Times in 178 Posts
Question Re: epoxy for use near gasoline
Larry--I sent you a email/PM did you get it--Thanx Comp 387
Old 08-15-2009, 11:10 AM   #5
Dragsinger
FED 387
check your PM
Larry Woodfin 471W
Old 08-15-2009, 02:57 PM   #6
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
permatex makes several epoxy kits for repairing gas tank leaks
http://www.permatex.com/products/Aut...ank_Repair.htm
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
