Old 08-03-2009, 02:18 PM   #1
Darcy Clarke
Liked 507 Times in 35 Posts
Default Who Sells the Adjustable Brake Pressure Launch Control Switches??
I was wanting the contact information for the adjustable brake pressure launch control with the brake pressure gauge.
Thanks
Darcy Clarke
Stk 6254 A/SA, F/SA, G/SA, H/SA
Darcy Clarke is offline   Reply With Quote
Old 08-03-2009, 04:53 PM   #2
M&M Motorsports
Default Re: Who Sells the Adjustable Brake Pressure Launch Control Switches??
I use a GEMS adjustable pressure switch. They are available thru industrial supply houses. Also, try E-Bay. I do not remember the model #, only that it is a 1/8 npt fitting. Also, it cost about $40-50 dollars. Hope this helps!
M&M Motorsports is offline   Reply With Quote
Old 08-03-2009, 06:29 PM   #3
chevy620
Banned
adjustable delay presure switches? Gee, just when I thought I left that stuff behind when I went Stock Eliminator racing .... guess not.
Maybe we should add adjustable pressure buttons for the brake pedal too?
Maybe just a small delay box....won't hurt anything, right?
I thought that stuff was for the Delay Box guys, guess not. That's pretty disappointing actually.
Jok
chevy620 is offline   Reply With Quote
Old 08-03-2009, 07:17 PM   #4
Darcy Clarke
Jok,
This is not a delay switch it works off of brake pressure, with no difference from a brake pedal switch and is legal and widely used. If these are illegal then brake pressure gauges should be as well.
Darcy Clarke
STK 6254 A/SA. F/SA, G/SA. H/SA
Old 08-03-2009, 07:23 PM   #5
Jim Storms
Liked 4 Times in 2 Posts
Cool Re: Who Sells the Adjustable Brake Pressure Launch Control Switches??
Darcy.. give me a call 425 941-8765 i know someone who has what your looking for...are you going to Montana??? Jim Storms
Jim Storms is offline   Reply With Quote
Old 08-03-2009, 11:10 PM   #6
Dave Jung
Dave Jung's Avatar
Liked 5 Times in 5 Posts
Can someone post the part number for the Gems adjustable pressure switch that everyone is using please? or any other brands that work. Thank-you.
6535 stk
81 Malibu K/SA
Dave Jung is offline   Reply With Quote
Old 08-12-2009, 05:59 PM   #7
Chuck1280
Your not allowed to use the finger button anymore?
Chuck1280 is offline   Reply With Quote
Old 08-12-2009, 08:18 PM   #8
Darcy Clarke
Hi Bob,
If I make it there I will buy the first round!!
Darcy
Old 08-15-2009, 02:22 PM   #9
Bench Racer
Liked 99 Times in 21 Posts
While on the subject, you used to see a lot of brake line pressure gauges in use. Normally how much pressure is required to lock the front brakes during a burn out, or staging the car? I know you see a lot of guys pumping the brake pedal as hard and quick as a Nascar jackman lifting the car for a tire change. Don Jackson
Bench Racer is offline   Reply With Quote
