Old 07-12-2009, 08:50 AM   #1
blapane
Default 1969 camaro fuel pump install
Looking for help,
Where are you guys mounting your electric fuel pumps and filters under
gen 1 camaros?Thanks
blapane is offline   Reply With Quote
Old 07-12-2009, 12:03 PM   #2
Z28-69
Default Re: 1969 camaro fuel pump install
In my case I took the factory exhaust hanger that mounts up high and duplicated it using wider steel and longer. Drilled holes to match factory. Took half hour to make and no new holes to drill.
Z28-69 is offline   Reply With Quote
Old 07-12-2009, 01:30 PM   #3
Liked 1,758 Times in 398 Posts
On one car, it is in the trunk, right next to the cell. NHRA tech has never said anything about it.
On the other, it was mounted sort of up in the rear axle hump, away from the stuff that moves. We bought that car that way, and never changed it.
