Old 07-09-2009, 06:27 PM   #1
FED 387
Liked 333 Times in 180 Posts
Default stock classification
If the engine factor is 23.08 and the shipping weight is 2770 what/ or how do you figure what class the car falls into??? comp 387
Old 07-09-2009, 06:39 PM   #2
Chuck Norton
Liked 89 Times in 19 Posts
Default Re: stock classification
If it's a V8 = U/S or U/SA
If it's a four or six cylinder = V/S or V/SA
if it's a four cylinder w/added weight = W/S or W/SA
If it's FWD = D/F
Chuck Norton is offline   Reply With Quote
Old 07-09-2009, 06:59 PM   #3
FED 387
Thank you but do you ever divide pounds per cube or cubes into weight when doing this??? Thanx FED 387
Old 07-09-2009, 07:07 PM   #4
Woodro Josey
Liked 3 Times in 1 Post
No Sir!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 07-09-2009, 07:24 PM   #5
FED 387
So 23.08 is how you determine which class you are in AND 2770 is the minumum the car can weigh for that class correct???... At what point does the 170 pound driver figure come into play as part of the 2770 or is it added to the 2770 or is the car weight 2770 LESS 170 to determine the minimum car weight???? Thanx FED387
Old 07-09-2009, 07:56 PM   #6
George Mirza
The basic formula is Factor x NHRA HP + #170 (driver)= Min. Weight.
The issue here is determining the correct factor for this combo. Like Chuck stated above, if it's a V-8 the heaviest V-8 class is U and the factor is 20.00 or more.
If it's a 4 or 6 cyl. it falls into V and the factor is 22.00 or more. (23.08 listed factor) So you use 22.00 as your factor for V.
Now all you need is the NHRA HP to figure your weight.
George Mirza is offline   Reply With Quote
Old 07-09-2009, 07:48 PM   #7
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
well, it's not the cubes that they divide into, it's horsepower (real or factored) but i'm waiting to be eddykated on how the drive weight stuff works.
i havent seem 170 lbs in 30+ years
