Old 06-22-2009, 08:03 PM   #1
Dennis Paz
Liked 5 Times in 3 Posts
Default 283/350 main brg?
Does anyone other than clevite make a main bearing to put a 283 crank in a 350 block?
Clevite only has one at standard and standard cranks are getting few and far between.
Dennis Paz is offline   Reply With Quote
Old 06-22-2009, 08:32 PM   #2
283SS
Default Re: 283/350 main brg?
here is bearing spacers
http://www.raceeng.com/p-7689-bearin...27-to-350.aspx
283SS is offline   Reply With Quote
Old 06-23-2009, 08:57 AM   #3
Ed Wright
Ed Wright's Avatar
Doesn't King still make spacer bearings? Thicker bearings, no spacers needed.
Ed Wright 4156 SS/JA
Old 06-24-2009, 09:24 PM   #4
Dennis Paz
I called king today and they no longer have anything for large to small journal conversion. I dont think I like the idea of spacers either. My current engine has clevite mains and is currently fine but for the future maybe an aftermarket 3.0 stroke crank or go back to a 283 block.
Old 06-25-2009, 06:06 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 779 Times in 193 Posts
The spacers will be fine if properly fitted. I have built motors with spacers for dirt track racers who have literally worn out the blocks with no problems. If those guys can't beak it, it's gotta be tough. Heck, I have even used an old set of bearings in the large journal block and align-honed it to fit with no problems. I always locked the spacers in place with Loctite stud and bearing mount and/or roll pins and never took them out after align-honing.
Old 06-25-2009, 09:07 AM   #6
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I agree with Dwight......I have used spacers that we made from std. bearings in a 400 block to install a 350 crank for a 377's. We line bored the bearings to size. I went thru the trouble of drilling thru the bearing spacer into the main saddle and tapping the hole for a machine screw. I used countersunk headed screws and ground them down to be sure they sat below the surface. Never had a problem using those for myself or my buddy and he really rpm'ed his stuff!! His motor generally saw 8200 on every run.....
Rich Biebel
S/C 1479
Stock 147R
