I have a 68 Mustang that I bracket race and it is VERY hard to push in Neutral. Just looking for suggestions as to what the problem could be. I know you stocker guys are masters about free things up so i figured i would ask here.
Liked 99 Times in 60 Posts
a few easy checks, with the front wheels raised, do they spin freely?
Next, are the rear brakes completely released? Also, try pushing with the drive shaft removed. These experiments will let you tune in on the problem system. Post your findings after performing the above checks.
Larry Woodfin 471W |
Liked 31 Times in 10 Posts
Good suggestions by Dragsinger, particularly the one to disconnect the driveshaft.
If your brakes aren't binding and its still hard to push, good chance you have a bent rear axle housing. I've seen this once before and heard of several other cases with the same root cause. Good luck and please do post your findings. |
If you have front disk brakes you might start there. My 67 had problems with the factory setup.
Liked 508 Times in 92 Posts
If the car has a spool in it, the rear can be bent causing the car to loose ET. That's if all the other standard stuff doesn't work.
Casey Miles 248H |
Liked 14 Times in 11 Posts
My old stock eliminator '73 Duster 340 had the stock disc brakes on it
and I never could get them to spin freely. I understand the new aftermarket disc brakes solve this problem. My currant bracket car also has stock disc brakes (all new pieces) and it does spin freely, so I hope I have eliminated that problem area.
Phil Saran Parker, Colorado |
You should try pushing some comp cars. I work turnaround at the Houston nats and most of those cars are a )(*^^ to push.
Next time wave all of your fingers at me. |
If the rear is bent how much ET could it be costing me. I only run 1/8th mile and the car runs 6.80's.
I had the car out in the driveway ths weekend and I loosen the brakes up.
The car pushed a little easier but not much. Next I took the driveshaft out and pushed the car and it was almost the same as when it was in the car. someone told if the rear end is set up to tight would that make the car hard to roll. |
Try Wades advice. A tight rearend wouldn't make that big a difference unles somethings really wrong. Must be some thing out of alignment.
