I plan to run stock and want to learn the ways of the QJet using my bracket car. But I can't get the engine to run below 1500 rpm's with the Q-Jet. spec. on engine, 350, 10.5 cr, 510 mech. cam, heads ported 461's -194/150, HEI, had a Holley 3310 and ran well.
Liked 2 Times in 2 Posts
Call danny ashley, best q-jet guy in the business, you won't regret it.
Danny can be reached at 765-674-5102.......3:30-7:30 est..... |
Was your carburetor built by someone who specializes in Q-Jet performance builds? If not you may want to consider sending it to one of a handful of guys that really know their stuff about Q-Jets. If you have a race prepped Q-Jet, the first place I would look to solve the high idle problem is look for vacuum leaks.
Nelson Kowal Stock 345 |
On another note, if your cylinder heads are ported, they are illegal to run in stock eliminator.
Liked 99 Times in 60 Posts
I have used Danny Ashley with very good results. The Q-Jet requires special prep with idle and off idle fuel, Danny knows what to do. Also, talk with Danny about "no rod jetting" Most racers run without primary metering rods. When you arrive at the correct set up for your engine, the idle will be good and the throttle response will be instant.
Larry Woodfin 471W |
i have just recieved a Danny Ashley q-jet, i havent run it yet but worth every cent just with the knowledge aquired from Danny. he emailed me a 'story book' on how to further dial in the q-jet once it is installed. you cant go wrong just calling him up ,super friendly guy
Dion Hildebrandt 6009 STK H/SA |
#7 | |
Liked 5,077 Times in 1,935 Posts
You might need to drill some holes through the primary butterflies to clean up the idle.
THANKS for the help.
Just a note, I'm using my bracket motor not a class motor yet, I was just trying the Q-jet, to seeing if I could get it work.. The carb is near new off a 400 in a truck and has not been work over. I know a built carb will be needed, but I need a litte help from MR.GREEN ( $$). John |
