Old 01-29-2009, 11:34 PM   #1
Tom Goldman
Tom Goldman's Avatar
Liked 885 Times in 238 Posts
Question PG &TH350 tailshaft bushings
Anyone know of a vender who still has babbet type tailshaft bushings for PG and 350?....All the venders I deal with are selling the bronze type which always are undersize on the bore if you have a good unworn yoke and have to be honed to fit......I've got about two dozen from different sources and all are the same. .....Tom
Old 01-30-2009, 01:44 AM   #2
Bill Edgeworth
Default Re: PG &TH350 tailshaft bushings
http://www.mcmaster.com/#frelon-lined-bushings/=dnv82
these may work for you. lots of other sizes are available from other sources. Bearing suppliers call them DU bushings.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 01-30-2009, 01:50 AM   #3
Bill Edgeworth
The link I just posted is not quite right, on their website go to page 1115
Old 01-30-2009, 09:54 AM   #4
63corvette
Liked 359 Times in 103 Posts
Just an FYI and you may be aware of this but the yokes are also made oversize and under size from std.
That is especially the case when you try to use a yoke made for a roller bearing on a bushing tail shaft.
There is a difference in size from the bushing to the roller bearing on the ID.
63corvette is offline   Reply With Quote
Old 01-30-2009, 10:49 AM   #5
Tom Goldman
Yes I am aware ,Actually the roller diameter yoke will fit these bushings as it has a smaller O.D....This is with the normal standard yoke. ......I normally do about 8 to 10 glides a month,most using the non roller tail. ....Bill, thanks for the link ,I'm going to check that out. .......This is more of an annoiance than a major problem, but the babbet bearings were also more forgiving for wear on the yoke. ....Tom
Old 01-30-2009, 01:11 PM   #6
Ken Haase
Hey Tom, I've got a Hughes Perf. bushing kit, part# HP6237, and it has the tailshaft bushing you're looking for. I'm not sure if that's the bushing they're still putting in those kits, because I've had this a while. Most front pump and larger case bushing are still the 'babbit' material, so why not the ext, hsg. bushing? I seem to remember the OEM GM parts bushing as the good one also. Hope this helps.
What do you use to hone the bronze type?
Ken
Last edited by Ken Haase; 01-30-2009 at 01:14 PM. Reason: Misspelled a word, can you believe it?
Ken Haase is offline   Reply With Quote
