Old 01-21-2009, 11:49 AM   #1
Notch1320
Default 2 Step Wiring?
Is the wiring in figure 2 in this link acceptable in Stock?
http://www.msdignition.com/instructi...pdf?terms=8739
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 01-21-2009, 10:16 PM   #2
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: 2 Step Wiring?
you should be good,i dont read or see any thing about the roll control having to be on its own circuit ,you might have to throw in a diode to eliminate back feed (used this set up when i ran my nash 5 spd works slick) gmonde
Oct. 19. 2007: Final decision on two-step usage in Stock eliminator
After reviewing nearly 500 responses from Stock-category racers regarding the usage of two-steps in Stock Eliminator, the NHRA Technical Department has rendered a final decision. Effective for the 2008 season, two-steps will continue to be allowed in Stock eliminator but must be either clutch- or break pedal-mounted and/or -activated. No remote button locations will be allowed.
gmonde
Old 01-22-2009, 02:22 AM   #3
Notch1320
Default Re: 2 Step / Clutch Switch Wiring in a Stick Car?
Is a relay acceptable in the 2 step wiring?
Someone currently running a stick must have some sort of answer?
Shawn Allsup
K/S 718
