Old 05-05-2008, 08:54 PM   #1
BRIAN SEATE
Default Moroso front springs / 69 Camaro stocker
How many coils should be cut out of new Moroso springs to attain proper ride height? My uncle has a big block 69 Camaro that he is prepping for pure stock. He already has Cal-Tracs and the split leaf setup. Been a long time since this was done on my 67. He wants a ride height like Bertozzis and Biondos 69 Camaros. Thanks for any help regarding this matter.
BRIAN SEATE is offline   Reply With Quote
Old 05-05-2008, 09:27 PM   #2
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: Moroso front springs / 69 Camaro stocker
you dont want to cut any coil springs if you can avoid it,you will achive ride height but you will loose the motion of the coil,there are few companys out there that custom build a set of coils to your specs,you will have to send them a sample with the mesured ride height ,just my 2 cents gmonde
Old 05-06-2008, 04:10 AM   #3
Bud Lefevre
Bud Lefevre's Avatar
Get what they recomend for your application, install them and let the car settle a few days before cutting any coils. Of course this is with the car ready to run with engine , fluids ect.
If your building a IHRA Pure Stocker, please email me off list.
Bud
Maliburac@aol.com
Bud Lefevre 3075 STK
IHRA World Record Holder
Bud Lefevre is offline   Reply With Quote
Old 05-06-2008, 11:53 AM   #4
mannymen
Liked 13 Times in 7 Posts
You can buy a set of Santhuff ($180) 200 or 225 lb springs, which are taller than the Moroso's ($90). You can buy the Moroso 213 Lb small block springs for a big block and only cut 1/4 off of the passenger side to offset the driver wgt difference and don't cut anything off of the drivers side.
I have used a set of 225lb springs (BBC Alum Head) and cut 2.25 coils(Drivers) and 2.25 coils(passenger), which was a mistake. I should have listened and only cut the driver 1/4 and the pass 1/2. The driver inner fender is now rubbing the tire, which is why I'm changing. Trial and Error is all I can say and only cut a 1/4 at a time which I didn't do.
mannymen is offline   Reply With Quote
Old 05-06-2008, 09:05 PM   #5
castle5
on my 68 camaro i bought the small block moroso springs. i have a big block. i also cut 1/4 coil out of passenger side. left driver side stock. i use moroso 7.10 tires. i install rubber bumpers on a frame to keep tires from hitting inner fenders on large wheelstands or heavy breaking..i had moroso big block spings in at first. after cutting them 3 times i was not happy. but the small block springs worked out well for us. can be a trial and error thing.
castle5 is offline   Reply With Quote
Old 05-07-2008, 12:24 PM   #6
Trevor
Guest
Posts: n/a
Contact Gary Wisecarver
Old 05-07-2008, 05:36 PM   #7
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Brian
If your uncle already has the Moroso spring, and he wants to give them a go, install them in the car 1st, before cutting anything off. Make sure the car is at the race weight. engine-trans -radiator- hood headers, all accessories, water etc., don't forget the driver weight.
when that is all done cut the steering wheel full left to full right a few times to settle the suspension. Then look at it and see where it is. If you'd like it to be lower, you should cut no more than a quarter of a coil off at a time and reinstall/evaluate etc.
Its a trial and error proceess, every car is a little different. Once you know what your car likes, it is easy to prepare a replacement set of springs when the time comes PS-(keep a notebook and write everything down)
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 05-07-2008, 09:16 PM   #8
Joe DeMarzo
Liked 113 Times in 9 Posts
Listen to Angelo, very sharp dude (my goomba) or if do not have the patience or time send your car to Kenny Koonce Jr in North Carolina and he will set up your whole suspension, front, back, 4 corners, etc....
Joe DeMarzo 1317 STK
