Old 04-30-2008, 12:12 AM   #1
n2oracer
Default Converter and gearing help...
Hey guys. I'm looking for some input on a couple of proposed changes. Here's a rundown of my combo:
BB Chevy 4.375 x 4.000 481"
12.50:1 CR
6.135 rods
990 heads with 2.25/1.88 11/32" valves
bowls blended, short side radius reworked, and chamber unshrouded
flow numbers are for #6 port (bad port) & no pipe on exhaust
.100 72/59
.200 143/113
.300 215/139
.400 261/165
.500 290/186
.600 306/204
.700 323/213
.800 333/216
Howards solid roller 7/4 swap
ADV 314/322
050 276/287
200 187/196
110 LSA/109 int CL
lobe lift .439/.430
valve lift .790/.731
rockers 1.8/1.7
Weiand 4150 Team G with 2" 4500 adapter
opened up on 4150 side(still has some venturi)
#9375 1050cfm Dominator (stock non HP style)
intake has no port work to plenum or runners
Hooker Super Comp headers for G-body
2" x 30" primary
3 1/2" x 10" collector w/ 12" ext
open headers
The engine is in a 84 Regal that weighs 3350# w/ driver. It has stock style bolt on suspension and 29.5" x 10.5" slicks. Trans is a Glide w/ a brake. The converter is a BTE 8" C100+. It goes 5400 against the brake. I don't know flash or shift recovery RPM. Rear gear is a 4.30 .
To date the car has had a best 60' of 1.44 on a good hooking track. The best time has been 6.65/105.1 with a spinning 1.54 60'(POS track). I'm thinking of trying a 4.86 gear and maybe having a new converter built.
What are your opinions.
n2oracer is offline   Reply With Quote
Old 04-30-2008, 01:52 AM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Re: Converter and gearing help...
If your going to run just 1/8th mile I would go with a 5.13/5.14. as for the converter...I would call ATI & ask them. I have been running ATI's stuff for 10 years & it just works! P.S. do ya have any room for a bigger tire? like maybe a 30x10.5 Hoosier radial? or a 29.5x11.5?? oh P.S.S. what low gear is in the glide? if it's a 1.76 you can pick up some GOOD E.T. by going with a 1.98 or 2.08... my old stocker picked-up .15 going from a 1.82 to a 2.08 no other change.
Old 05-07-2008, 11:20 AM   #3
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: Converter and gearing help...
You trying to bracket race or go fast?
You need work on the suspension/tire combination, you have the HP to run 105, should be leaving at mid 1.3's and going 6.40's - 6.50 .
I've had 29.5-10.5's on my ride but it works better on 9" tires, since I can't fit a wider rim.
Lots of cam and carburetor on it.
Are you using a two-step?
What are the suspension specs?
Dave Goob Cook is offline   Reply With Quote
Old 05-07-2008, 10:22 PM   #4
Todd Geisler
Liked 345 Times in 149 Posts
Somethings definately wrong with the car if you look at the parts used vs the current performance.
I run a 3400 lb 79 Malibu with a 461 bbc , naturally aspirated. Engine has 13 to 1 compression, 269/276 @ .050, .738"/.710 roller, 1000HP 4150 Holley, th400 with a 6000 rpm flash converter, 4.33 gear and a 28" tall tire. Launched off the footbrake anywhere from 2000-3000 rpm, shifts made at 7500 rpm, turning 7700 rpm at the stripe. Typical ET's are 9.50's @ 140 mph, 60's in the high 1/2x to low 1.3x.
As good brought up, large carb, big cam both want rpm to get working. Then a glide which is gonna be soft off the line unless you give it alot of rear gear and alot more stall.
If you want to compare notes, my e-mail is geislert@qis.net.
good luck
Todd
Todd Geisler is offline   Reply With Quote
