Liked 3 Times in 1 Post
what is the best way to remove the white lettering from the race tires?
Thanks for the info.... Wade O |
Liked 2 Times in 2 Posts
I have a nutty friend that I go racing with that takes the white lettering off of his tires too, he uses Afta, I wont tell you who he is but he runs a blue Camaro with a wicked EFI 305 motor.
Liked 216 Times in 77 Posts
I leave mine on untill they start looking bad then a little brake clean ( non clorinated) on a rag takes the rest off with a quick wipe.
Last edited by Rob Petrie E395; 04-23-2008 at 01:08 PM. Reason: correct spelling |
Just like Rob said...non-chlorinated brake cleaner works well. It also works well in removing grease stains from carpets and rug material. The non-chlorinated brake cleaner is the same stuff used by dry cleaners on your clothing.
Liked 5 Times in 3 Posts
Thinner works. I have a tip for you guys on cleaning your tires too. First before you spray any water on the car...( I use Westley's bleach white or Wal-Mart's tec 2000 wheel cleaner) spray cleaner on dry tire & wheel. Then with an old sponge dipped in the soapy water & wash the tire & wheel...the black shxx will just roll off the tire! I then lay the sponge on the ground & rinse with garden hose as to not dirty my wash water...makes the tires look brand new!
Thanks for the tip Greg. The brake cleaner works great!
Thanks for the info.......... Wade O |
