I have a race gas question.
I have always run VP C-12. Now, my local distributor only carries Sunoco. I can still get VP, but have to drive a bit farther to get it. Will the 110 octane Sunoco work as well as the VP? Any help is appreciated. Thanks. Jeff Goss 6990 SS/MA |
Better.
Jeff,
Check the 'reid vapor pressure' differences between the fuels if possible, especially with a low compression motor. Reid vapor pressure (RVP) is the ability of the fuel to vaporize. VP publishes their RVP but not sure about Sunoco. Octane is a 'burn retardent' with basically no impact on fuel energy content (btu/lb); it ust affects how it burns. |
Don,
Thanks for the reply. I found a website that lists the RVP for the different race fuels. http://www.smithtex.com/racing/fuelcomp.html It shows Sunoco Supreme with 8.0. VP C-12 is 7.75. I need to read up a little more, but Sunoco should be in the ballpark or a little better? The higher RVP should make it vaporize quicker? Motor is a 327-250 horse with the 4GC Carb. Small valves and 10.25:1 compression. Jeff |
Liked 880 Times in 311 Posts
Jeff,
When Steven made up that list he also included a list of Terms we use with fuel. It give you some info about what all the terms in the chart are. Go back and take a look at it. Adger Smith
Adger Smith (Former SS) |
Guest
Posts: n/a
The problem you can run into is inadvertantly mixing the VP fuel in with your Sunoco fuel as NHRA uses VP as the "official" fuel and Sunoco wont be sold at an NHRA event. Even straight Sunoco seems to be a problem with NHRA tech at times.
I would rather use Sunoco as it's roughly 30% cheaper than VP. Personally, in my application, I can't tell any difference between the two brands; other than in the wallet. NHRA #7494 SS/H 1970 AMC AMX "Best Appearing" @ NHRA '06 Pacific Sports Nationals JeffLeeAzRealty@Qwest.net 602-418-9797 |
Thanks a bunch for the good info!
Jeff |
Liked 5 Times in 3 Posts
Jeff i've always run sunoco 110....my buddy Mike Galuk had his car @ my house having some work done to it (changing oil plugs) well while we were messing around with it we ran it out of fuel...C12.....all i had was sunoco....so we put that in the car & went and got him a jug of it. he left & went to Byron for a div. race.....it was the quickest he had ever run. (& this ws in the middle of summer)
novamoation
Jeff, please EMail me your phone number and a good time to reach you. I live in W.V. so there is a time difference. Mike. LGaluk@aol.com
Mike Galuk JOE COOL RACING Stock-2080 |
Jeff (Goss):
Reid vapor pressure numbers are as follows... ...the lower the RVP number is numerically, the less volatile (i.e., harder to vaporize) the gasoline is. Using your info, the C-12 is slightly less volatile than the Sunoco, however I would consider both fuels fairly close in range. I would also compare the density of the fuels to determine impact on your carb settings. And as Jeff Lee pointed out, I wouldn't mix them, unless you like hanging out at fuel check and answering lots of questions... |
