Old 03-26-2008, 09:48 PM   #1
Robbie Welch
Liked 262 Times in 124 Posts
Default Towing with 5.9 L in a motor home
I've been looking at a 91 Monaco Dynasty 34' it has a 230 Hp 5.9 L with a 6 speed trans. I'd be towing a 28' triple axle trailer with a door car, golf cart and tools probably around 10000 lbs Does anyone tow with something similar to this, can it handle this much weight and how's it tow. Thanks for your help Robbie
Old 03-27-2008, 01:27 AM   #2
crewchiefpro
Guest
Posts: n/a
Default Re: Towing with 5.9 L in a motor home
I have a 95 Fleetwood with similar trailer. It tows fine, and the mileage is much better than bigger engines ( I get 10 mpg if I go 60 mph ).
Old 03-27-2008, 08:14 AM   #3
slow dragster
slow dragster's Avatar
Liked 6 Times in 4 Posts
Not enough HP/Torque, I have driven several back to back. We tow 7500# with a 300HP Cat / 860# torque 8 mpg @ 70 mph and it seems ok until you hit the mountains. I would suggest higher torque and a side radiator for cooling. The rear radiator with an intercooler gets hot if they are not cleaned and maintained.
slow dragster is offline   Reply With Quote
Old 03-27-2008, 09:48 AM   #4
Jason Oldfield
Jason Oldfield's Avatar
Liked 10 Times in 4 Posts
Send a message via AIM to Jason Oldfield Send a message via MSN to Jason Oldfield Send a message via Yahoo to Jason Oldfield
Honestly Robbie, I'd keep looking. I have a 1996 32' Itasca Suncruiser that has one of the high-output 454's in it, and it's sufficient, but I've been thinking recently about putting a Banks system on it to give it more power. I tow a single car, 24' trailer with a 4-wheeler (probably about 10,000 lbs. total), and by no means do I feel like I have all the power I could ever want, especially on hills. It's not as bad as my Durango was as even on the steepest hills I'll never fall below 50 mph, but cruising at 73 mph it loses speed or downshifts even with the slightest grade.
I don't know how much you're looking to spend, but you should be able to find a mid-90's RV pretty cheaply that has the Chevy 454 or Ford 460. Ideally, you'd want a diesel pusher, but I realize that's not in everyone's budget (mine included).
Just my $0.02....Good luck...
Jason Oldfield
S/G & S/St 1838
Jason Oldfield is offline   Reply With Quote
Old 03-27-2008, 10:09 AM   #5
G E T Racin
I had a 1995 35' safari with a 250hp cummings. Chassis wise it was fine and towed no problem. Untill I got to the hills. Then it was a real dog.
Now I have a 1997 40" HR imperial with a 325 cummings. Set the cruise at 75 and forget it. MH weighs 4k more and I'm using the same trailer - a 28' dual axle haulmark at about 8500lbs.
60 mph just ain't my style, sorry don
Gary T
G E T Racin is offline   Reply With Quote
Old 03-27-2008, 01:03 PM   #6
Robbie Welch
Yea I was thinking it would be a little short on power, but it looked so nice I had to do some checking. A Gas house is a possibility. Thanks for the reply's Robbie
