Old 06-28-2025, 11:02 PM   #1
Jim Hawkins
Liked 115 Times in 35 Posts
Default Question for stick racers
What are you guys using for a pilot bearing or bushing?
I have been using a ball bearing in a bushing made to fit in the back of the crankshaft. This is the larger hole where the convertor hub would fit.
Problem is getting one made for each specific crank and fit needs to be about perfect.
Also can have clearance problems to the splines on the input.
I tried a bushing from speedway once that has a shoulder for extra height with a motor plate. It spun loose after very few runs.
I have a torrington type bearing here from moroso goes in stock pilot hole.
Anyone use these? Believe this is used in some oem applications.
Jim Hawkins is offline   Reply With Quote
Old 06-29-2025, 09:40 AM   #2
james schaechter
Liked 1,443 Times in 302 Posts
Default Re: Question for stick racers
The sealed bearing is best, but you have to have it set when the crank is out. I have used the needle bearing bushing in stockers but they do wear out. I have also used the Kevlar ones in a pinch.
The modern clutches we all use put more strain on the pilot bearings so anything other than a good strong roller bearing is going to get wobbled out and can cause issues. Thst is ok as long as you keep an eye on it and are prepared to change them as needed.
James Schaechter 3163 STK
Old 06-29-2025, 12:43 PM   #3
I have used roller bearing, in place of a bushing, but let's just say they are unforgiving.
I had to indicate the bell housing and re-balance all the clutch components...then it was fine.
Old 06-29-2025, 01:22 PM   #4
Robbie Draughon
Liked 29 Times in 5 Posts
Lakewood 15975. For chevy engine and the bigger ford pilot size. Have run these for years.
SS/AM 2917
Robbie Draughon is offline   Reply With Quote
Old 06-29-2025, 09:19 PM   #5
Jim Hawkins
Yes you just answered my next question. Upgrade to the Ford pilot size.
Thanks for all replies.
Old 07-01-2025, 02:06 PM   #6
Dirk Olson
Liked 172 Times in 46 Posts
Call G Force have them in two motors with different crank manufactures and I have had no problems. I used to get them from Jerico but these fit much better.
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
