Old 03-06-2025, 09:59 AM   #1
hrs1326
Liked 19 Times in 10 Posts
Default Stock Super Stock weight
Coming back to NHRA after many years away. I recall there was once a rule that when moving class up or down there was 250 maximum weight. AM I remembering that correctly, and because I cant find it in current rule book I assume its gone?
hrs1326 is offline   Reply With Quote
Old 03-06-2025, 01:32 PM   #2
jmantle
Liked 174 Times in 83 Posts
Default Re: Stock Super Stock weight
I don't think that has been in the rule book for years. I have to add 300 lbs to switch from U to V, no one has ever questioned it in 12 years. Make sure the weight you add is properly secured, they do check for that.
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 03-09-2025, 11:15 AM   #3
ken robinson
Liked 225 Times in 88 Posts
From O/SA and down the index's farther apart by more than .15 . Which makes is harder too move up or down a class . Some times your stuck at naturel class at min.weight + 130 lbs for driver . Then look at who's in that class and how far under they run. The index's for stock & SS are listed in the racer info . What combo's are you looking at at ?
Old 03-09-2025, 08:37 PM   #4
joe collins
Liked 23 Times in 17 Posts
I thought it was 170 lbs for driver
joe collins is offline   Reply With Quote
Old 03-09-2025, 10:41 PM   #5
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: Stock Super Stock weight
It's plus 170 lbs for the driver. Jim
