Old 01-29-2025, 04:08 PM   #1
Lyn Smith
Liked 1,002 Times in 203 Posts
Default No oil to rockers?
Purchased a set of Comp hydraulic lifters and it is now getting some oil to the rockers. The difference between the two lifters is that the side oil hole is just a little higher on Comp parts. Thanks to all that sent suggestions.
Lyn Smith is online now   Reply With Quote
Old 01-29-2025, 04:38 PM   #2
Hacksaw
Liked 315 Times in 178 Posts
Default Re: No oil to rockers?
Wrong lifters? Spinning the drill CCW instead of CW?
Old 01-29-2025, 04:40 PM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Rotate the crank. Also what drill? typically need a good 1/2” electric drill
Old 01-29-2025, 05:14 PM   #4
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
Originally Posted by Lyn Smith View Post
Have a 283 street engine in my 63 Nova cruiser. Just changed the cam and lifters and I'm getting no oil to the rockers. Have tried priming it multiple times. Usually even if you don't get a steady stream out of the push rods you will get a few bubbles when priming with the drill and dummy distributor. Have the engine on my run in stand. Have started the engine and run it for 30 seconds. Has 60lbs oil pressure but no oil to the pushrods. Any ideas?
Originally Posted by 1320racer View Post
Rotate the crank. Also what drill? typically need a good 1/2? electric drill
Stan
Old 01-29-2025, 05:22 PM   #5
1320racer
1320racer's Avatar
He editted his original post 7 minutes after my reply adding that Info dumbazz
Old 01-29-2025, 05:50 PM   #6
1legjerry
Liked 72 Times in 15 Posts
If all you did was change cam and lifters(nothing else) then I would say you got the wrong lifters. What year 283?
Have some work the drill and then turn the crank by hand at the same time.
1legjerry is offline   Reply With Quote
Old 01-30-2025, 01:04 PM   #7
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
The very early 283 (57), with the part number 3731548(as did the 3720991 265's) had a notch in the rear cam journal surface to basically link the block oil galleys at the # 5, the far back one feeding the rockers. It used a thinner cam plug at the back to not block that hole and if the newer style plug was used it would. Thus no oil up top. The trick was to either grind a feed hole in the block at the rear cam journal linking the two oil feed holes. Or oblong the hole in the # 5 cam bearing to link the two.
Not sure if this is the case with your 283 but just a thought. I don't know when GM made the change in the blocks,I believe it was the late fifties but i really don't know. These blocks also had no provisions for side mounts which your '63 would need.
If you did just a straight camshaft and lifter swap and not changed the rear cam plug when things worked before,this is not the problem. But just a thought.
Also on the very early 55-57 small blocks, if you used a newer style distributor instead of the original with a notch at the bottom that distributor would fill with oil as it could not drain back through the block. So mods were needed there too.
55 Chevy is offline   Reply With Quote
Old 01-30-2025, 05:24 PM   #8
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
if nothing has been done with cam bearings and was oiling before cam change...
early small journal blocks have to have groove/flat spot in cam...pull lifter and spin drill and see if oil is flowing out of oil galley in lifter bore
if all that is right look at lifters... pull lifter apart and you should see a clear path for oil to pass and go through pushrod seat..
there will be a disc(valve) that sits against bottom of pushrod seat and there should be away for oil to go between disc and pushrod seat. it may have a embossed/raised place stamped in disc with a small spot that isn't embossed,leaving a small groove for oil to pass. some have the bottom of pushrod seat curved, both styles I have seen not oil.basically the disc seals against the bottom of pushrod seat and has a small place for oil to flow through.. if it does'nt which is a defect I cut a small groove in bottom of pushrod seat so oil can pass between disc and pushrod seat to oil pushrod/rocker..
lifter should have oil hole on outside in the groove,have seen them missing...
if hole is in body above oil band then it wrong for hydraulic
Old 01-30-2025, 07:03 PM   #9
Lyn Smith
Removed the intake and pulled out #8 cylinder exhaust lifter. Spun pump over and oil gushes out of the open hole. Lifters seemed to be pumped up, but still no oil out of top of them. Going to install a set of Comp hydraulics tomorrow.
Old 01-30-2025, 07:48 PM   #10
Barry Polley
Guest
Posts: n/a
Lyn, Leave lifters in and spin pump, look for too much oil escaping onto cam and beliw lifter. Sounds like it?s not getting to the pushrod oil hole on the side. - thus the slot I was talking about. If it has two holes only barely slot one.
Pm sent
