Liked 25 Times in 8 Posts
I don't want to constantly change my adjustable. Please lets me know and how much you would want for them. Thanks
Liked 1,362 Times in 367 Posts
idk what ignition you are using now, I guess an analog 6al from msd. Have you considered going to a programmable one? I use a programmable 6al now in my super gas car and it's really easy to use and infinitely adjustable.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
Liked 44 Times in 14 Posts
These are very easy to make yourself. Simply measure the resistance of the variable limiter chip for the various RPMs you want, and then shop Amazon or an electronics supply store for the resistor values you need (you can probably pickup a pack of standard-value resistors for $10 - $15). 1/8 or 1/4 watt resistors are fine with 5% (or better) tolerance. The plug connectors can also be sourced on Amazon or at electronic supply outfits; they're not critical.
Once constructed, you can cover them with heat shrink tubing to keep contaminants out of the circuitry.
Dave White NHRA Stock/SS 606 |
Liked 178 Times in 59 Posts
If you have several 3000 chips, measure them with an Ohm meter. The one with the least resistance will probably come close to a 2900 or even 2800 rpm.
Tom Flowers E/SA 3860 |
