Old 05-19-2024, 06:10 PM   #1
Mike Graham
Liked 341 Times in 67 Posts
Default Fast xfi 2.0 O2 sensor setup
Anyone with any experience with the Fast xfi 2.0? The oxygen sensor always reads 15.94 on the gauge panel and the monitor. I have replaced the sensor and checked the harness for damage. I don't see any calibration procedure in the manual. Any help would be appreciated.
Mike Graham is offline   Reply With Quote
Old 05-19-2024, 10:44 PM   #2
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
Default Re: Fast xfi 2.0 O2 sensor setup
If the sensor is in the collector it will show 15.94 much if not all the time the engine isn’t under a load.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 05-20-2024, 06:15 PM   #3
StockerStang912
StockerStang912's Avatar
Liked 21 Times in 7 Posts
Hi Mike - make sure you select the right sensor type in System Configuration. There's 2 options to choose from (L1H1 and LHA) and will provide a different reading if the incorrect version is selected.
Greg Viscome
193 GT/QA
StockerStang912 is offline   Reply With Quote
