Old 04-30-2024, 03:31 PM   #1
Mike Graham
Liked 341 Times in 67 Posts
Default 2014 cj power windows
Trying to get windows to work on this car, checked all the usual suspects. Fuses/power
Is there some sort of interlock on these cars that keep the windows from working?
Mike Graham is offline   Reply With Quote
Old 04-30-2024, 07:05 PM   #2
Kirk Morgan
Liked 81 Times in 45 Posts
Default Re: 2014 cj power windows
I went to the Ford Racing site and printed the wiring diagram for my 2013 CJ. I looked at the 2014 and a diagram wasnt listed. The switches send a ground signal to a relay or module to operate the windows.
Kirk Morgan is offline   Reply With Quote
Old 05-01-2024, 12:49 AM   #3
Mike Graham
Thanks Kirk. I have those diagrams. I have checked power and ground on motor and switch. Do you know if the signal goes to the BCM?
Old 05-01-2024, 07:36 AM   #4
RKelliher
Liked 188 Times in 62 Posts
If oe system ,may need BCM to be programed. I know on GM if you change switch bcm must be reprogramed
RKelliher is offline   Reply With Quote
Old 05-01-2024, 07:38 AM   #5
Robin Lawrence
Sponsor
Liked 717 Times in 121 Posts
The BCM is not required for the windows. The door harnesses use the door handle switch to activate the drop in the window as the door is opened to clear the door seal.
When I built my CJ I used the stock connectors in the door jambs. There are a couple of wires from the driver side that are needed to mate the system. I powered the positives in the wires that went through the stock harness in the door jambs and it all worked.
Before I was able to complete the wiring I located a NOS CJ Harness and used that.
Robin
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
Old 05-01-2024, 09:58 AM   #6
Mike Graham
Robin
This car appears to have the stock harness in it. Do you remember what wires had to be connected? I don't see anything in the Dunn Rite schematics.
Thanks
Old 05-01-2024, 02:02 PM   #7
Kirk Morgan
Mike give me a call i can tell you what i did when RJ and i built a 2010 CJ from scratch. I made all the wiring harnesses. 210-887-3331
