Hey all,
I have a 66 Chevelle Malibu with a 283 SBC, powerglide, and 12 bolt. I’m trying to decide what makes the most sense to upgrade to go faster. I’m Not trying to set the world on fire, just trying to pick up 2 tenths or so. Below is what I have that I know of and wanted to get some thoughts here from people who have seen increased speed in their combos. I went 11.80 this past weekend for reference at 800’ but 15mph head wind Engine 283 SBC 520 cast number heads (brand new not sure who machined them) Scorpion rocker arms 1.6/1.7 Comp cam push rods 8.000 .080 Bullet cam Crower lifters Dart block Carb 4GC completely redone by DeanO Transmission Power glide 2.18 low gear A1 7” converter Rear end 12 bolt 5.86 gear (I think!) Other items Drum brakes #3465 with me in it |
Liked 3,252 Times in 989 Posts
I’d attack weight, chiefly the brakes. TBM brakes can take weight off and decrease rolling resistance.
#3 | |
Liked 8,245 Times in 1,541 Posts
Liked 1,953 Times in 439 Posts
M.J. is correct. A 200 Metric.
If this is a stocker, I didn't know high ratio rockers were legal..... Not knowing who did what to the heads, it's hard to say what potential is there.....
Alan Roehrich 212A G/S |
I should have prefaced. This is a SS/NA car.
I’ve heard 3 speed which was an obvious choice in my head however I’m not sure which direction of 3 speed to go these days. I had a pro trans in my sunfire and that was fast but it needed replacement parts every 30-40 runs it felt like. I’d love to get a turbo350 with a trans brake that would be sturdy enough for when I move classes next year into FGT. Thanks for all the insight CR! |
Whether or not you need a 350 depends on what you intend to do later. Usually, a foot brake is faster than a trans brake. And the three speed trans brakes don't work as well as a PowerGlide brake.
Since you're talking about Super Stock, it makes a big difference who did the heads.
Liked 58 Times in 36 Posts
Best BANG for the buck is a SS Hemi! When they go BOOM they make a big BANG! Lol
SS/AH 328X |
#8 | |
Liked 178 Times in 59 Posts
Tom Flowers 3860 E/SA |
Hey PJ,
I would change to a 350 turbo and a ATI converter. Swap out the brakes for some strange disc brakes. Put ceramic wheel bearings in. That should get you .2 better. Then I would start working on heads/cam. It will take a bit but it will pay off. Pops |
I run a different brand SS/MA;
According to my calculations if you are @ 217 HP you only need to weigh 3205. Your car fits into SS/NA you would run on a 3 tenths slower index (12.15) and in fact would only weight 3425 which is less that you stated you currently are weighing. For a dollar's worth of N stickers at the hardware store you get those three tenth. However, I would double check the weight on your cars as it seems that it really should be about 3200 with you in it (My apologies if you are 400 Lbs yourself) and weigh a couple hundred pounds like me. We spend a lot of nights in the shop finding ways to get weigh either out of or at least shifted back in our racecars.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 06-30-2024 at 06:23 PM. |
