Old 03-12-2024, 06:02 PM   #1
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Stock/SuperStock Teardown
Although this is always a controversial subject, perhaps its time to move
forward on this, and realize it is not 1980 anymore.
Presently, I have seen 3 different types of teardowns. 1) Where carbs or
throttle bodies have been checked, camshafts have been checked, and the entire car has been given the once over. 2) The more traditional teardown
where all the above is done, plus removing a head and having it poured,
bore & stroke, etc. 3) The traditional teardown Plus pull the motor, check
cranks, rods, pistons, blocks, etc.
While we like when our competitors get a 2 or 3 teardown, nobody thinks
it happens often enough. I don't know that we have the ability to change
that. NHRA does it when they want, how they want.
To make it easier on everybody physically & mentally, I think we could be a little happier, if all Class Winners, LODRS Winners, and National Event Winners had at least Teardown # 1, PLUS, an inspection with a camera of the cylinder, piston dome, valve reliefs, valves, etc. This would be followed by a P&G to get total cubic inches.
Perfect? Not by a long shot. Better, I think so. At the very least, it's a thought starter that you can add to, modify, or maybe even like.
J.R.
J.R. Haddad is offline   Reply With Quote
Old 03-12-2024, 06:47 PM   #2
RonB
Liked 50 Times in 15 Posts
Default Re: Stock/SuperStock Teardown
I think you are on to something. Borescopes have gotten very good, very small, and very cheap. It would be quick & easy to take a look at intake runners and ports, for example.
Ron B.
RonB is offline   Reply With Quote
Old 03-12-2024, 07:22 PM   #3
Jeff Stout
Liked 708 Times in 285 Posts
Drain oil from pan you can scope thru the drain plug and look at crank and rods.
Old 03-12-2024, 08:29 PM   #4
nickh
nickh's Avatar
Liked 694 Times in 206 Posts
On my dirt motor (IMCA) we have to have site plugs on one side of our oil pan for inspection. Like the ideas mentioned above even though I do not drag race anymore. It does and will keep everyone honest.
Old 03-12-2024, 09:08 PM   #5
Tom Meyer
Liked 354 Times in 120 Posts
IMCA like Nhra lack tech people with knowledge, they both once had pre tech, not so much any more.
Tom Meyer 5240 SS Stock ???
Old 03-12-2024, 11:32 PM   #6
Jeff Stout
Just started getting involved with dirt cars. The IMCA and street stocks take the top 3 after race and tech them what they wanted to see. One night it was all 4 shocks, go no go gauge in 2 barrel carb was used once, front spindles and heads have to have IMCA stamped on them. For a 200 to win they are getting checked pretty well.
