Is there any benefit or performance gain to pulling timing out in high gear?
#2 | |
Liked 520 Times in 176 Posts
That will depend on your engine combination. What you might actually find is to run a little more ignition advance off the starting line and down the track and retard the timing to your regular amount just after you've shifted into high gear. The best way to determine the best total timing for your engine combination is to run on the dyno at various ignition timing settings. Also this will let you know how much fuel the engine wants. As far as I know you can't measure "Drivability" on an engine dyno. I hope this helps, have a Good Day. Respectfully, Henry Kunz 1534 H/SA |
#3 | |
Sponsor
Liked 714 Times in 120 Posts
Your trigger method will play a big part in what it wants as well. A flying magnet crank trigger or reductor on a late model will not have a "natural retard" like a distributor pickup on an engine with a timing chain and distributor gear at the far end of the camshaft. I have seen some want more timing and others want less after peak torque. On my combination it doesn't seem to make any difference on the engine or chassis dyno. It does seem to make a difference at the track in the later gears. Testing is the only way to really know. The latest deal in Factory Showdown is in cylinder pressure analysis. Thats a little past my budget LOL. Robin
STK 308 SS 3088 |
