Liked 1,471 Times in 308 Posts
I'm thinking of installing an accusump on my LS motor. When I do things
like this, I always find out why I shouldn't have done it, after I've done it. Would like some real world opinions from people with experience in dealing with accusump type of installations. Thanks, J.R. |
Liked 170 Times in 55 Posts
Pros
Keeps oil pressure from dropping when stopping after burnouts & braking at the end of the run. Allows to run a Lower oil level in pan if desired. Allows prelubing the engine prior to start. Can be operated mechanically Can be operated electrically, Both on-off and/or Engine oil pressure reading. Cons Additional weight of canister, oil & plumbing. Space to mount canister and route plumbing
Div 3 Sales, Service and Tech for many manufacturers |
Liked 109 Times in 44 Posts
everything Steve said-I saved a Buick 455 block when they started getting scarce and had kinda wide main clearances (for a street car) with an Accusump-prelubed on startup when the key went to on, street/stripped that thing for years like that
Scott McIntyre-Cornville-retirement at last! 2015 Chevy SS. LS3/ 6 spd Stick-Wolf in sheeps clothing! |
Liked 299 Times in 48 Posts
We run accumulators on both of our cars, and have the electric solenoid connected to the ignition switch on them both as well. The only con is the small amount of additional weight, but I think the pros greatly out-weigh that. With this setup, we always turn on the ignition switch and let the motors prime until the oil pressure falls back to 5-10psi before we fire the cars up each morning. And of course the motor gets a full prime everytime you go to start it up so it's just a great insurance for every bearing and lubed surface. Highly recommend these to anyone, it's a great investment!
Thanks Guys. I really appreciate the feedback. Mike, as always I owe
you another one. Pretty soon you'll be able to right me off on your taxes!! Thanks Again, J.R. |
Liked 463 Times in 60 Posts
I like having an accumulator and recommend using the Canton EPS smart valve regardless of who's accumulator you choose
#7 | |
Liked 114 Times in 29 Posts
Liked 759 Times in 379 Posts
