Liked 33 Times in 20 Posts
I have a Rossler 350 Turbo that I busted the case on. We switched everything into a ATI Supercase but are having trouble with it. It is stuck in 2nd or 3rd gear and does not change when shifted. It goes into park, reverse and neutral with no problem. Any one run into a problem like this?
Frank Beasley (828)234-5753 |
Liked 360 Times in 121 Posts
Not with that case in particular but we had issues with an ATI glide case. It kept burning up the front pump bushing. After talking to a major trans player and my converter builder, he has had issues with those cases with core shift. We switched everything to a Dedenbear case and zero issues since.
#3 | |
Liked 1,923 Times in 432 Posts
You Rossler valvebody may not be compatible with the ATI case. Rossler stuff works, but some of it is absolutely a brand of its own. Not knowing which gear it is in kind of makes it hard to even guess.
Alan Roehrich 212A G/S |
Liked 48 Times in 13 Posts
Check that the valve location is where it needs to be.
I had to heli-braze about .100 to get valve where it needed to be in relation to the valve body. |
