Old 02-16-2023, 08:05 PM   #1
Doug Domm
Liked 84 Times in 21 Posts
Default Hoosier 18213????
Hoosier has this tire listed as NEW. It’s a 9x30 drag radial but also listed as 9.9” tread width and a C30 compound. Is this a Legal stocker tire? It may have the 9x30 imprinted on the sidewall But???? And where does that C30 compound fit in the spectrum? If you follow the transition of their compound scale is that tread rock hard? What is the target application of this tire?
Doug Domm is offline   Reply With Quote
Old 02-19-2023, 01:28 AM   #2
Dave Noll
Dave Noll's Avatar
Liked 238 Times in 111 Posts
Default Re: Hoosier 18213????
I've only used an M/T Radial
BUT
G/Y has a radial that measures just about Identically.
The rulebook says "may not exceed 10" wide regardless of wear".
Dave Noll, EF/S ,?/SA 6526
Old 02-19-2023, 04:31 PM   #3
nhramnl
Liked 358 Times in 83 Posts
Give Hoosier a call and just ask them your questions. They have always been good to deal with and they should know their product (and its intended applications) better than anybody.
Old 02-24-2023, 03:25 PM   #4
tiremaster
Liked 7 Times in 4 Posts
This tire is Stock Eliminator approved. It has been run on Factory Showdown cars of Chris Holbrook and Doug Hamp. The compound I am told has more grip then the C06 but is tougher. Hope this helps
tiremaster is offline   Reply With Quote
Old 02-26-2023, 11:08 PM   #5
Doug Domm
Thank you very much. That is what I was interested in hearing.
