Old 01-07-2022, 07:49 PM   #1
Bruce Fulper
Liked 54 Times in 33 Posts
Default What we need is lifter prevention
Yes, Lifter failure prevention....
Does anyone know or can someone find out what the hyd flat tappet lifter hardness should be so we can test them first? I have a hardness tester. Most engine shops do. I've got to find this out and soon. Not worried about making a small mark on the side of the lifter close to the bottom when testing. Easy to smooth out.
Bruce Fulper is offline   Reply With Quote
Old 01-07-2022, 08:49 PM   #2
SSDiv6
Default Re: What we need is lifter prevention
What's the goal?
First, you need to have some understanding of metallurgy and have knowledge of the material you are testing and any finishes and treatments.
Many materials will change its original properties after being exposed to chemicals, heat and mechanical impact.
Old 01-07-2022, 09:00 PM   #3
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
I checked patents. 56-62 R
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 01-07-2022, 10:08 PM   #4
Gmirza
Liked 253 Times in 95 Posts
To get an accurate hardness it’s best to test on a ground flat surface. If you test on the radius or side of the lifter there is a correction factor you need to use. It’s usually in the directions for the tester.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 01-07-2022, 11:05 PM   #5
Bruce Fulper
I need to let you all know, I was a mechanical nuclear inspector for 7 years. Working with all kinds of exotic metals. I used to teach guys how to use a hardness tester. So thanks for the dire warning of what I might need to know, but I got it covered. And thanks for the numbers Terry.
Old 01-08-2022, 05:59 AM   #6
Terry Cain
Terry Cain's Avatar
Wonder what happen to Schubeck's tooling?
Terry Cain ???? STK
Old 01-08-2022, 09:33 AM   #7
Keith 944
Keith 944's Avatar
Liked 1,887 Times in 579 Posts
You Could of said that you stayed in a holiday inn express.
Sorry, please continue, these recent threads have been interesting
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 01-11-2022, 10:16 PM   #8
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
Soo I would guess Lifters failing is still an issue? I have read Lifters are too soft and failing. Is this a material problem or a machining problem?
Rose Racing is offline   Reply With Quote
Old 01-12-2022, 01:20 PM   #9
Doug Hoven
Liked 870 Times in 165 Posts
Lifter failure is definitely still an issue. That being said when you read all of the stories online of how people are wiping out lifters left and right, I would personally take them with a grain of salt if they don't specify things such as if they used proper assembly lube/break in oil, valve spring pressure, and break in procedure. I do however believe that there are some lifters out there that are inferior to others. I recently made some discoveries regarding who manufactures certain brands of lifters nowadays and was able to buy new Johnson solid flat tappet lifters even though Johnson does not sell them direct anymore.
1189 F/SA
Defunzalo Racing Enterprises
