Old 12-12-2021, 02:54 PM   #1
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
Default Coil Spring Compressor for 1971 Ford
Whats the best coil spring compressor for Ford front suspension?
Rose Racing is offline   Reply With Quote
Old 12-12-2021, 03:14 PM   #2
Rory McNeil
Default Re: Coil Spring Compressor for 1971 Ford
What style of Ford front suspension? For the unibody shock tower type, I always used the regular 4 hooked threaded compressor. What I did, was remove the front shocks, drop the compressor inside the spring from above, using a leaf spring U bolt on top of the tower for the compressors upper hooks to grab, and then used the screws nut to compress the coil enough so that I could unbolt the upper control arms inner shaft bolts, and swing the arm out of the way, and then release the tension on the spring, to remove it.
NHRA 6390 STK
M/S 85 Mustang
Old 12-12-2021, 04:57 PM   #3
partsbob67
Liked 79 Times in 11 Posts
https://www.autokrafters.com/images/...dium/22851.jpg
the best i've ever used.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 12-12-2021, 05:32 PM   #4
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
All of those are good unless you're working on a 64 Fairlane. They are a different animal. A real mean animal.
Old 12-12-2021, 06:05 PM   #5
Rose Racing
for the record old springs are out of the car and im trying to get the new ones compressed enough to put them in. How does the Auto krafters one work for springs outside the car?
Old 12-12-2021, 06:08 PM   #6
Rose Racing
and the old shock tower type front suspension with a unibody frame
